Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
The Kindle 3 was the 3rd generation of Kindle produced by Amazon. It can in a WI-FI or 3G configuration with 4 GB of internal storage.
71 Vragen Bekijk alle
Kindle 3 g Repair
The screen shows the screen saver that appears when the device is shut down the device does not turn on to read. The on off switch appears to be ok can anyone suggest a solution . New screen? Have tried to reset device numerous times also removed battery in an attempt to reset
Is dit een goede vraag?
Commentaar:
This question was migrated from http://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Make sure that battery is connected properly, I'd bet your messing with it disconnected it or similar.
I'd advise leaving it to charge for several hours, to ensure it's charged.
Then go for a hard reboot, hold the power switch and keep it held, after 30 seconds or so (sometimes more than a minute) the device should reboot, which almost always works.
If all this still doesn't work, I'd advise getting a new battery (though before buying one I'd suggest contacting amazon's customer support, often they'll just do this stuff for free).
Was dit antwoord nuttig?
Score 1
Do you know who can repair my kindle
Voeg je antwoord toe
John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,897
