Ga door naar hoofdinhoud
Repair guides and support for the 5th generation Chevy Caprice. Manufactured by GM's Australian subsidiary, Holden.
3 Vragen Bekijk alle
How to rise car suspension
Hi
I recently purchase Caprice 2004 LTZ. I want to rise the body on car little higher. So may i know, how to rise body on suspension about 10-20 cm.
Thanks
Is dit een goede vraag?
Score 1
1 Opmerking
I know this is an old question but be careful raising the suspension of a car without a solid diff. As these cars usually have live rear axles, raising them without a correct kit as Old Turkey suggested will cause binding of your axles. Resulting in tyre wear, suspension issues and not to mention handling problems.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Mujahid Latif, I definitely would go with a commercial lift kit. It does have all the parts and instructions to install it. Try places like this or on here
Was dit antwoord nuttig?
Score 1
Your coils springs may need some replacement due to its age. Or you can add some rubber lifter to lift the area you want.
1 Opmerking:
Another thing to check is the shock absorbers once the shocks becomes busted the end result would be a bumpy and uneven height.
door
Voeg je antwoord toe
Mujahid Latif zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 930
