Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1963 Vragen Bekijk alle
broken #5 cable inside iPhone 3GS, can it be fixed?
I was replacing the battery in my iphone 3gs, and somehow broke the #5 ribbon cable that connects to the motherboard, can this be fixed?
Is dit een goede vraag?
Een opmerking toevoegen
2 Antwoorden
Het nuttigste antwoord
Flex Cable #5 on iPhone 3GS (and iPhone 3G) is the Headphone Jack Flex Cable. It has internal (power button, volume buttons, mute/vibrate button). The replacement of this Flex Cable is considered among the most difficult repair of all iPhones past and present.
Was dit antwoord nuttig?
Score 2
Without looking at the inside of one, I believe what you are referring to is the antenna connection. You can either simply replace the charge port, which comes with a new one or you can remove one from an old charge port.
Voeg je antwoord toe
chadcorkren89 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 676
