Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
3GS turns off at ~60%
My 3GS turns off at appx. 60 % - Will power on again only when charger connected.
In diagnose log following error is displayed:
Reset count:0
Boot failure count:1
Boot faults: rst vdd_under
Boot stage: 80
Boot app: 0
Is this causer by bad battery or?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
I have changed many batterys that die at higher percentages than you would think. Best solution is to purchase a battery and follow the guide here on ifixit to install, or find someone who can help you out. This will resolve your issue 99/100 times.
Was dit antwoord nuttig?
Score 1
This would in fact be the cause of a bad battery.
Same problem for me with my iphone 4, but just reset or keep the screen black until push the on/off button to turn on but not ask for pin code....:
Diagnose log error:
Reset count:0
Boot stage: 255
Boot app: 0
Is this causer by bad battery too?
Thanks in advance.
Voeg je antwoord toe
reenee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,331
