The M11x R2 (Revision 2) is Alienware's 11 inch updated version of the original M11x laptop, featuring a i5 520UM or a i7 740UM processor in the american models.
4 Vragen Bekijk alle
Computer is running slow. Graphics are lagging badly.
The M11xR2 has coped well in the past but lately in on line games it is lagging very badly with a FPS rate below 10. I have upgraded drivers and have made sure the Nvidia graphics card is set to run high performance but it makes no difference. I don't think the problem is overheating as even when just turned on the problem is there. It makes no difference if it is cabled or wireless connections. Any help would be appreciated.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
5 Antwoorden
Gekozen oplossing
Here is a link to a source for manuals including service manual for your computer. Hope this helps.
http://support.dell.com/support/edocs/sy...
Was dit antwoord nuttig?
Score 1
If your Hardware is pretty much compatible with game requirements than you have to go through some points before playing game to prevent your PC from slowing down:-
- Shut down all running updates
- Remove all temporary files from your system
- You must have enough memory on disc that can support your paging memory
- Shut down all background running applications
- Run Reginout Utility for extreme gaming experience
- Update DX on your system
Thanks, Hope I helped.
Score 1
this can be fixed in few simple steps just follow - remove all other unwanted programs from you computer and all unwanted add on , clear junks and trojans if u have and restart the system
thanks
Score 1
Hi,
Facing lag dose not always mean the problem is with your VGA only you might experience lag due to some other process holding the processor to cause a memory choke for system processes. Try extending the memory (RAM) for your laptop and see if you still face lags in while gaming.
Good Luck
Overheating can occur straight away if there is dust inside:
http://forum.notebookreview.com/alienwar...
Voeg je antwoord toe
Anthony Kearns zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 5
Afgelopen 7 Dagen: 41
Afgelopen 30 Dagen: 179
Altijd: 9,682
