<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;iPhone 16 Plus&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/iPhone_16_Plus?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;iPhone 16 Plus&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 03 Aug 2026 02:13:09 -0700</pubDate>
<item>
<title><![CDATA[iPhone 16 Plus: Does the iPhone 16 Plus have a gasket on its sim tray]]></title>
<description><![CDATA[<p>General Outlook</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/901117/Does+the+iPhone+16+Plus+have+a+gasket+on+its+sim+tray</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/901117</guid>
<pubDate>Fri, 23 May 2025 04:36:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 16 Plus: Panic log help: 16+ battery stuck at 1%, stops charging when booted]]></title>
<description><![CDATA[<p>Hello, I was hoping someone could help me decipher the panic log on an iPhone 16 Plus. The phone charges normally when first plugged in, but stops charging as soon as it's fully booted (the charging icon still shows up, but no power is going to phone) and the battery indicator always shows &quot;1%&quot;. It then crashes after ~3min.</p>
<p>I've already replaced both the battery and the charging port (with aftermarket parts from IG), but neither has impacted the behavior of the device.</p>
<p>I believe the relevant part of the panic log is here:</p>
<pre class="code code_unknown" style="white-space:pre-wrap" translate="no">&quot;panicString&quot; : &quot;panic(cpu 0 caller 0xfffffff03eba9a94): SMC PANIC - ASSERT: target\/d48a\/target.cpp:248: 0, SMC BSC failure, TB0T SBAP\nspreadsheet ver(*10) 110\nS.sensor array 0 - 7 is 169, 0, 0, 0, 0, 0, 0\nF.sensor array 0 - 1 is 0\n\n - Misc(2) OUTBOX1 not ready\nASSERT: target\/d48a\/target.cpp:248: 0, SMC BSC failure, TB0T SBAP\nspreadsheet ver(*10) 110\nS.sensor array 0 - 7 is 169, 0, 0, 0, 0, 0, 0\nF.sensor array 0 - 1 is 0\n\n\nRTKit: root</pre>
<p>As far as I understand, the &quot;SMC BSC failure&quot; indicates a sensor not communicating with the SMC, and the &quot;TB0T&quot; lead me to suspect the battery. However, the behavior is identical with the original battery and the replacement battery. There's no obvious liquid or physical damage to the device.</p>
<p>Anyone know what sensor is being indicated, or what the issue is if I'm totally misreading it? I can post more of the log if helpful. Thanks so much,</p>
<p>Henry Chung</p>
<p>⟐ Answered juli 12, 2026 at 8:54 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/963430/Panic+log+help:+16++battery+stuck+at+1%25,+stops+charging+when+booted</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/963430</guid>
<pubDate>Sun, 12 Jul 2026 08:54:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 16 Plus: Why do all games keep lagging and only sometimes adjust to 60 FPS]]></title>
<description><![CDATA[<p>Sometimes it just stays locked in at 30 FPS and I have to restart the game and wait for it to adjust to 60 FPS sometimes it keeps switching between 30 to 60 FPS every half a second and only after like 30 minutes, it starts to run at 60 FPS. I checked every setting even the game settings and there’s nothing limiting frames per second. How can I fix it? And the games are lightweight like geometry dash, levels like button masher, and Roblox private servers.</p>
<p>⟐ Commented oktober 05, 2025 at 6:06 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/920455/Why+do+all+games+keep+lagging+and+only+sometimes+adjust+to+60+FPS</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/920455</guid>
<pubDate>Sun, 05 Oct 2025 06:06:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 16 Plus: I had a Panic CPU 4 Caller in my panic log]]></title>
<description><![CDATA[<p>Hi,</p>
<p>Please help. My new iPhone 16 Plus had a sudden shutdown and when I checked analytics, it shows a panic full and says Panic CPU 4 caller. Can you please help me identify if it is a software or a hardware issue. The Apple service center was too far from my location so I needed some insights if this crash needed an urgent service or it can be resolve with troubleshooting.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1yPQZjVaSDLrFqEL.standard" width="104" height="225" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1yPQZjVaSDLrFqEL.full&quot;, '', 'width=1290,height=2796')" /></div>
<p>⟐ Commented september 22, 2025 at 20:51 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/918526/I+had+a+Panic+CPU+4+Caller+in+my+panic+log</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/918526</guid>
<pubDate>Mon, 22 Sep 2025 20:51:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 16 Plus: iPhone 16+ No wifi or cellular]]></title>
<p>After my iPhone 16+ was dropped I now have no cellular connection or wifi anyone seen this before or have any ideas?</p>
<p>Thanks</p>
<p>Ollie</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/966523/iPhone+16++No+wifi+or+cellular</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/966523</guid>
<pubDate>Sun, 02 Aug 2026 13:37:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 16 Plus: Front camera doesnt work after motherboard swap]]></title>
<description><![CDATA[<p>Hello, on iphone 16 plus i recently swapped motherboard to icloud locked phone, (I took camera from same phone where was motherboard), it works but on all components expect rear camera it says they are locked but work, but face id and front camera dont work. It just say issue. I tried restoring via dfu mode with apple devices app but it kept giving me error 53. I managed to restore with 3u tools but it didnt fix the issue. I also tried using icloud locked camera, but it just said its locked and didnt work. Is there any way to fix it ? Would buying another genuine icloud unlocked cam fix it ?</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/923382/Front+camera+doesnt+work+after+motherboard+swap</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/923382</guid>
<pubDate>Sat, 25 Oct 2025 11:28:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPhone 16 Plus: كيفية إزالة حساب I claud من الأيفون How to Remove an iCloud Account]]></title>
<description><![CDATA[<p>كيفية إزالة حساب i claud من الأيفون</p>
<p>Translation Arabic - English</p>
<p>How to Remove an iCloud Account from an iPhone</p>
<p>⟐ Edited augustus 22, 2025 at 9:04 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/913382/%D9%83%D9%8A%D9%81%D9%8A%D8%A9+%D8%A5%D8%B2%D8%A7%D9%84%D8%A9+%D8%AD%D8%B3%D8%A7%D8%A8+I+claud+%D9%85%D9%86+%D8%A7%D9%84%D8%A3%D9%8A%D9%81%D9%88%D9%86+How+to+Remove+an+iCloud+Account</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/913382</guid>
<pubDate>Fri, 22 Aug 2025 09:04:35 -0700</pubDate>
</item>
</channel>
</rss>
