<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Water Softener&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Water_Softener/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Water Softener&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 18 Jul 2026 10:50:40 -0700</pubDate>
<item>
<title><![CDATA[Water Softener: Morton water softener stopped working]]></title>
<description><![CDATA[<p>Hi,</p>
<p>My Morton water softener M34 has some issues. It has enough salt but complaining that the salt level is low. I tested the water hardness and it shows &gt;200.</p>
<p>Does anyone have experience repairing one?</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/921436/Morton+water+softener+stopped+working</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/921436</guid>
<pubDate>Sat, 11 Oct 2025 14:52:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Softener: CSI signature series (1) control valve troubleshooting]]></title>
<description><![CDATA[<p>Hi we have error code 3 which is an issue with the control valve? I think I need to take the cover off and check for debris? The manual is very vague and unhelpful.</p>
<p>⟐ Commented december 15, 2024 at 9:27 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/880411/CSI+signature+series+(1)+control+valve+troubleshooting</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/880411</guid>
<pubDate>Sun, 15 Dec 2024 09:27:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Softener: Flow Meter Sensor for Culligan CTM Softener]]></title>
<description><![CDATA[<p>Hi there!</p>
<p>I have a Culligan CTM Top Mount Softener. I understand that one end of the cable is supposed to connect to the main control board (done that!), but i am having a hard time figuring out what the other end (where the plastic sensor is located) is supposed to go. Any hint will be much appreciated!</p>
<ul><li>Kevin</li></ul>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/6VKAE6vG1RHqZXRi.standard" width="282" height="206" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/6VKAE6vG1RHqZXRi.full&quot;, '', 'width=1228,height=900')" /></div>
<p>⟐ Answer edited november 30, 2023 at 22:41 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/826378/Flow+Meter+Sensor+for+Culligan+CTM+Softener</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/826378</guid>
<pubDate>Thu, 30 Nov 2023 22:41:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Softener: Shot in the dark for Hall Sensor for Culligan]]></title>
<description><![CDATA[<p>I have a Culligan Gold series watersoftener. My unit can measure water flow. The way it does this is through a hall sensor that measures a small impeller that spins as the water flows. There is a magnet in the impeller that is read by the hall sensor.</p>
<p>I have tested the sensor by digging it out of it's epoxy bed and injecting 5 volts, it seem to be bad.  I can't read any markings on the sensor. I don't know if it's a north or south sensing. (I don't know anything about hall sensors, only what I have learned in the last few days. I want to solder in a new sensor. It's about 4mm wide.</p>
<p>⟐ Commented januari 18, 2023 at 0:13 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/764370/Shot+in+the+dark+for+Hall+Sensor+for+Culligan</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/764370</guid>
<pubDate>Wed, 18 Jan 2023 00:13:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Softener: How to repair a water softener?]]></title>
<description><![CDATA[<p>Is there a repair manual for water softener?  Our's is a  PRO Series E  E-70.</p>
<p>It just cycles won't turn on, release the water.</p>
<p>⟐ Answered december 18, 2022 at 21:20 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/149547/How+to+repair+a+water+softener</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/149547</guid>
<pubDate>Sun, 18 Dec 2022 21:20:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Softener: Pipe draining so much water and water softener is making a noise.]]></title>
<description><![CDATA[<p>I have a water softener  Pro E Series E-70. It seems to be draining water to my laundy room. there is an extra white pipe . the pipe has been going for 1 hr and at the same time the water softener is making a loud noise.  Is this normal?</p>
<p>⟐ Answer edited oktober 24, 2022 at 2:34 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/251893/Pipe+draining+so+much+water+and+water+softener+is+making+a+noise.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/251893</guid>
<pubDate>Mon, 24 Oct 2022 02:34:51 -0700</pubDate>
</item>
</channel>
</rss>
