<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Water Gun&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Water_Gun?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Water Gun&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 17 Jul 2026 10:30:23 -0700</pubDate>
<item>
<title><![CDATA[Water Gun: Why wont my water gun shoot]]></title>
<description><![CDATA[<p>When I pull back the trigger on the x shot zuru hydro hurricane water gun it dosent shoot</p>
<p>⟐ Commented juni 25, 2025 at 9:27 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/801324/Why+wont+my+water+gun+shoot</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/801324</guid>
<pubDate>Wed, 25 Jun 2025 09:27:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Gun: How do you fix a nerf super soaker water gun that leaks in many place.]]></title>
<description><![CDATA[<p>My nerf super soaker has been leaking and the water pressure has been very low. Every time I try to pump the water gun it squirts out a must or a tiny stream of water. Do you guys know how to fix this?</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/582407/How+do+you+fix+a+nerf+super+soaker+water+gun+that+leaks+in+many+place.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/582407</guid>
<pubDate>Sat, 03 Aug 2019 19:02:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Gun: The tip of water gun]]></title>
<description><![CDATA[<p>What is that small part at the tip called ?</p>
<p>⟐ Answer accepted juli 21, 2017 at 6:50 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/391060/The+tip+of+water+gun</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/391060</guid>
<pubDate>Fri, 21 Jul 2017 06:50:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Gun: Why is my trigger coming back slowly once pulled?]]></title>
<description><![CDATA[<p>Just some random cheap amazon water gun that has a moving slide that's supposed to move with each trigger pull. However that's malfunctioning because the trigger resets really slowly after each pull, meaning rapid fire shots don't cause the slide to move all the time. I've tried cleaning the pump out with soapy hot water but nothing's worked. Any fixes or should I just cut my losses and trash it?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_11_05_Num_25" class="header">Update (11/05/25)</h3></div>
<p>Should probably also mention the only screws I could take off just removed the slide, no direct access to the pump. I'd rather keep the gun as it's a neat little prop, but it's not too expensive to throw away.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/wY1MmMcH4Iq5hGmJ.standard" width="282" height="158" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/wY1MmMcH4Iq5hGmJ.full&quot;, '', 'width=1920,height=1080')" /></div>
<p><br />Photo for clarity.</p>
<p>⟐ Edited by author november 05, 2025 at 15:52 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/925015/Why+is+my+trigger+coming+back+slowly+once+pulled</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/925015</guid>
<pubDate>Wed, 05 Nov 2025 15:52:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Gun: Why is my X-Shot Stealth Soakers trigger only going halfway]]></title>
<description><![CDATA[<p>My water guns trigger only goes halfway making it only 50%. Could anyone help me???</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/908924/Why+is+my+X-Shot+Stealth+Soakers+trigger+only+going+halfway</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/908924</guid>
<pubDate>Thu, 24 Jul 2025 08:56:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Gun: Nerf "CROSSBOLT Crossbow trigger wont release draw string]]></title>
<description><![CDATA[<p>sorry water gun was tthe closest match</p>
<p><strong>the crossbow works perfectly up to the npoint of firing, when the trigger is pulled the drawstring isnt released completely. My thoughts on it are maybe the drawsting has lost some tension as if i flick it after pull9ing the trigger it fires the dart, or the trigger is being obstructed internally. If anyone has experienced the same fault  and repaired said fault i would appreciate thier comments thank you<em>'</em></strong>italic text<strong><em>'bold text</em></strong></p>]]></description>
<link>https://nl.ifixit.com/Answers/View/439907/Nerf+%22CROSSBOLT+Crossbow+trigger+wont+release+draw+string</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/439907</guid>
<pubDate>Fri, 10 Nov 2017 20:52:50 -0700</pubDate>
</item>
</channel>
</rss>
