<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Water Dispenser&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Water_Dispenser?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Water Dispenser&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 31 Aug 2026 15:10:55 -0700</pubDate>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Water from cold water dispenser is not cold.]]></title>
<description><![CDATA[<p>Water from cold water dispenser is not cold.</p>
<p>⟐ Answer accepted december 19, 2023 at 5:50 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/152212/Water+from+cold+water+dispenser+is+not+cold.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/152212</guid>
<pubDate>Tue, 19 Dec 2023 05:50:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Why is my cold water not cold?]]></title>
<description><![CDATA[<p>My water cooler was working and all of a sudden the water is not cold. What do i do?</p>
<p>⟐ Commented december 05, 2022 at 18:10 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/170267/Why+is+my+cold+water+not+cold</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/170267</guid>
<pubDate>Mon, 05 Dec 2022 18:10:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Dispenser freezes the water in the reservoir]]></title>
<description><![CDATA[<p>The cold water slows and then stops as a block of ice forms in the inside of the dispenser. In removing a panel on the rear that has 4 screws, I see on either side of the unit there are  rheostats with an adjusting screw. What is needed?</p>
<p>Model Number GXCF25FBS</p>
<p>⟐ Answer edited augustus 12, 2026 at 9:10 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/53133/Dispenser+freezes+the+water+in+the+reservoir</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/53133</guid>
<pubDate>Wed, 12 Aug 2026 09:10:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Why won't my bottom load water cooler pull water from the jug?]]></title>
<description><![CDATA[<p>My bottom load water cooler won't pull and dispense water from the jug.  We've tried another bottle and made sure the cap with water tube is securely inserted. What can I try to fix it?</p>
<p>⟐ Commented mei 04, 2026 at 21:55 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/764521/Why+won&#039;t+my+bottom+load+water+cooler+pull+water+from+the+jug</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/764521</guid>
<pubDate>Mon, 04 May 2026 21:55:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: The water cooler is leaking, what might be the culprit?]]></title>
<description><![CDATA[<p>What is the best way to  figure out where the leaking water is coming from and what may be causing it?</p>
<p>⟐ Answered april 28, 2025 at 4:27 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/286091/The+water+cooler+is+leaking,+what+might+be+the+culprit</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/286091</guid>
<pubDate>Mon, 28 Apr 2025 04:27:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: cold water wil not come out]]></title>
<description><![CDATA[<p>the water will not come out ,the green light stays on all the time</p>
<p>⟐ Commented juni 17, 2022 at 22:25 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/193847/cold+water+wil+not+come+out</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/193847</guid>
<pubDate>Fri, 17 Jun 2022 22:25:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: My free standing water dispenser is leaking from the bottom]]></title>
<description><![CDATA[<p>I have a hot/cold free standing water dispenser and it is leaking.  I wonder if they can be repaired and if so where do I go.</p>
<p>⟐ Answered december 19, 2019 at 1:20 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/414869/My+free+standing+water+dispenser+is+leaking+from+the+bottom</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/414869</guid>
<pubDate>Thu, 19 Dec 2019 01:20:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: How do I clear or fix an E4 error code]]></title>
<description><![CDATA[<p>I get an E4 error code and have unplugged for 24 hours and restarted but still get E4 code and unit automatically shuts off</p>
<p>⟐ Commented oktober 27, 2022 at 11:31 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/342419/How+do+I+clear+or+fix+an+E4+error+code</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/342419</guid>
<pubDate>Thu, 27 Oct 2022 11:31:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Why does our water taste like dirt?]]></title>
<description><![CDATA[<p>I have removed the water bottle and drained all the water from the water cooler.  I have wiped clean the inside where the water lays from the water bottle.  The water still has a dirty taste.  What to do?</p>
<p>⟐ Edited december 19, 2023 at 5:55 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/250824/Why+does+our+water+taste+like+dirt</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/250824</guid>
<pubDate>Tue, 19 Dec 2023 05:55:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: dispenser is leaking internally]]></title>
<description><![CDATA[<p>The dispenser (GE) stand alone....water leading ...appears to be internal issue.</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/340839/dispenser+is+leaking+internally</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/340839</guid>
<pubDate>Thu, 29 Sep 2016 18:00:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: How I make the water cooler]]></title>
<description><![CDATA[<p>is there a dial for coolder water</p>
<p>⟐ Answered juni 08, 2021 at 23:05 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/118948/How+I+make+the+water+cooler</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/118948</guid>
<pubDate>Tue, 08 Jun 2021 23:05:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: hot water did not work]]></title>
<description><![CDATA[<p>hot water did not work</p>
<p>⟐ Commented juli 25, 2021 at 12:18 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/389176/hot+water+did+not+work</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/389176</guid>
<pubDate>Sun, 25 Jul 2021 12:18:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: How to clean the piping etc of the Water dispenser.]]></title>
<description><![CDATA[<p>It is easy enouph to take the bottle down to clean the reachable parts of the dispenser but how does on clean the internal piping of the dispenser?</p>
<p>⟐ Commented oktober 12, 2017 at 15:58 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/87935/How+to+clean+the+piping+etc+of+the+Water+dispenser.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/87935</guid>
<pubDate>Thu, 12 Oct 2017 15:58:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Why there is no proper flow from hot outlet]]></title>
<description><![CDATA[<p>thw cold water outlet working smoothly, but very slow water coming out from hot water outlet. this is Class pro water bottled dispensor. i already cleaned using vinegar with hot water, but still the same condition</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/380546/Why+there+is+no+proper+flow+from+hot+outlet</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/380546</guid>
<pubDate>Sun, 05 Mar 2017 20:51:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: GE Profile Tri Temperature water dispenser will not heat water]]></title>
<description><![CDATA[<p>Will not heat water, even though hot water switch is in on position (l).  Water dispenser is plugged in.  Instructions warned that hot water function would be destroyed if hot water tank ran dry.  This never happened.  Unit purchased Sept 2004.   House fuse is not blown. (Electrical outlet functioning &amp; green light on unit is &quot;on&quot;) Checked to see if temperature limiter was tripped by setting hot switch to off (O) for five minutes, and then set to on (l) for 30 minutes. Red hot indicator light on front of unit does not turn on indicating heating cycle.</p>
<p>⟐ Answered september 15, 2020 at 11:13 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/35289/GE+Profile+Tri+Temperature+water+dispenser+will+not+heat+water</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/35289</guid>
<pubDate>Tue, 15 Sep 2020 11:13:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Nestle water dispenser user's manual]]></title>
<description><![CDATA[<p>The hot water is leaking without pressing it.. It is flooding all the time while bottle is on the dispenser.. How to fix it?</p>
<p>⟐ Commented maart 23, 2026 at 20:54 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/722973/Nestle+water+dispenser+user&#039;s+manual</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/722973</guid>
<pubDate>Mon, 23 Mar 2026 20:54:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Water leakage from water dispenser]]></title>
<description><![CDATA[<p>I just replaced the water bottle in my water dispense but the water starts leaking to the floor from the sides and rear of the dispenser.</p>
<p>⟐ Answer deleted september 03, 2021 at 23:17 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/328828/Water+leakage+from+water+dispenser</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/328828</guid>
<pubDate>Fri, 03 Sep 2021 23:17:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Locating Hot Water RESET]]></title>
<description><![CDATA[<p>I currently own the Crystal Mountain “Storm” bottle water dispenser. I moved the unit recently, now the water is not heating properly - at all. I’ve attempted to toggle the switch up front with no luck. I cannot find any useful info online for locating the hot water RESET button in the rear. I’d appreciate any useful ideas or solution. Thx!</p>
<p>⟐ Answer edited juli 25, 2021 at 13:26 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/700321/Locating+Hot+Water+RESET</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/700321</guid>
<pubDate>Sun, 25 Jul 2021 13:26:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: What would cause the water from my dispenser to leak out onto the floo]]></title>
<description><![CDATA[<p>GE Profile water dispenser is leaking water out onto the floor.</p>
<p>⟐ Answered mei 19, 2019 at 9:23 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/568325/What+would+cause+the+water+from+my+dispenser+to+leak+out+onto+the+floo</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/568325</guid>
<pubDate>Sun, 19 May 2019 09:23:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Why is my ge water dispenser leaking?]]></title>
<description><![CDATA[<p>I put a jug of water on my ge water dispenser i got from my dad and the water leaks out the bottom. Help.. i have well water</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/273524/Why+is+my+ge+water+dispenser+leaking</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/273524</guid>
<pubDate>Fri, 27 Nov 2015 21:32:44 -0700</pubDate>
</item>
</channel>
</rss>
