<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Samsung B1445A Washing Machine&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Samsung_B1445A_Washing_Machine?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Samsung B1445A Washing Machine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 26 Jul 2026 01:36:36 -0700</pubDate>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Washing machine door won't unlock?]]></title>
<description><![CDATA[<p>My washing machine cycle came to an end. After 3 minutes it is supposed to unlock, but it didnt. It has drained all the water out, so that's not a problem. I turned the power off on the wall, and it still wouldnt unlock. How can I get my wet washing out?</p>
<p>⟐ Commented augustus 02, 2023 at 12:09 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/83303/Washing+machine+door+won&#039;t+unlock</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/83303</guid>
<pubDate>Wed, 02 Aug 2023 12:09:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: loud knocking on spin cycle]]></title>
<description><![CDATA[<p>Hello. When our samsung front load washer gets to the spin cycle it sounds like horses are galloping through the laundry room.  It is under warranty. They replaced shocks....just as bad or maybe even worse. If you are in the room it's so loud you can not hear a person talk beside you. I read a few of the other questions of similar nature on here but didn't see on where shocks had already been replaced and checked that not clothing or foreign objects in machine.  I video recorded the sound when I turn drum by hand. The bang happens when you move the drum so simple to reproduce the noise. The tech  seemed stumped so I thought I'd ask professionals online. Thank you for any ideas.</p>
<p>⟐ Commented september 01, 2025 at 12:26 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/282179/loud+knocking+on+spin+cycle</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/282179</guid>
<pubDate>Mon, 01 Sep 2025 12:26:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Door ERROR during wash - interlock fault?]]></title>
<description><![CDATA[<div class="imageBox imageBox_center"><img src="https://guide-images.cdn.ifixit.com/igi/o2AsgrnVG4DS5BdF.standard" width="183" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/o2AsgrnVG4DS5BdF.full&quot;, '', 'width=650,height=800')" /></div>
<p>About a year ago (almost to the day!!!), I had a load of washing that I couldn't get out of my washer because the door wouldn't open. Upon investigation I found that the door interlock has burnt out. I'm not sure what the piece is called that connects to the interlock (connector block?), but it was badly burnt and slightly melted, although the 3 metal contacts were still intact. Some of the interlock was damaged too, so I bought a new interlock and fit it to the burnt connector and it has been fine since. But this evening during a wash, my machine started beeping to say there was a door error - that it wasn't closed. When I pushed on the door, I heard a buzzing noise and the lock icon was shown on the display, but when I tried to rerun the wash, it said the same error. I'm not sure what to do? Do I buy a new interlock, or is the connector the problem - if so are these replaceable too, or does it mean I need a new machine? :(</p>
<p>⟐ Answer accepted januari 22, 2026 at 12:14 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/121530/Door+ERROR+during+wash+-+interlock+fault</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/121530</guid>
<pubDate>Thu, 22 Jan 2026 12:14:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Pourquoi j'ai de l'eau qui coule du bac de savon-adoucissant]]></title>
<description><![CDATA[<p>Lorsque la machine charge l’eau, l’eau déborde par le bac de savon-adoucissant<br />Au début du cycle, et avant le rinçage</p>
<p>Google translate:</p>
<p>Why do I have water flowing from the softener soap tub.</p>
<p>When the machine loads the water, the water overflows through the soap-softener tank At the start of the cycle, and before rinsing</p>
<p>⟐ Answered maart 22, 2025 at 5:39 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/702548/Pourquoi+j&#039;ai+de+l&#039;eau+qui+coule+du+bac+de+savon-adoucissant</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/702548</guid>
<pubDate>Sat, 22 Mar 2025 05:39:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Washing machine is unblanaced]]></title>
<description><![CDATA[<p>My washing was doing fine until I overloaded it. It makes a load banging noise now. I turned the drum inside and as it turns 360 it makes a clunk noise and feels like it jumps out and back in again on the turn. I hope that makes sense. It makes a loud noise when it washes and spins since i overloaded it.</p>
<p>⟐ Answer accepted oktober 01, 2019 at 3:11 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/593757/Washing+machine+is+unblanaced</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/593757</guid>
<pubDate>Tue, 01 Oct 2019 03:11:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Samsung front load power shut down and door locked]]></title>
<description><![CDATA[<p>My Samsung front load washer power shut down and the door is locked. I tried the outlet and no response. I can’t even get the model number since the door is locked . I don’t know if this will help but the Samsung washer is a super speed power foam stem VRTplus . I never had issues with it and it suddenly stop while the machine was running.</p>
<p>⟐ Answered juni 11, 2024 at 7:08 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/689866/Samsung+front+load+power+shut+down+and+door+locked</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/689866</guid>
<pubDate>Tue, 11 Jun 2024 07:08:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Why is my washing machinedoesnot work.?CL is in the display]]></title>
<description><![CDATA[<p>Why is  my washing  machine  doesn't  work?CL is  in  the  display  ==</p>
<p>⟐ Answered december 11, 2025 at 12:01 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/229631/Why+is+my+washing+machinedoesnot+work.CL+is+in+the+display</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/229631</guid>
<pubDate>Thu, 11 Dec 2025 12:01:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Why my washing machine smuggling water when spinning water from below]]></title>
<description><![CDATA[<p>when i use my washing machine and after start it , i see a lot of water come from under the machine when its spinning, and one can help me to fix it&gt;</p>
<p>⟐ Answered juli 13, 2022 at 17:13 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/740031/Why+my+washing+machine+smuggling+water+when+spinning+water+from+below</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/740031</guid>
<pubDate>Wed, 13 Jul 2022 17:13:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: loud noise on rinse and spin cycle..what can I do to fix this]]></title>
<description><![CDATA[<p>2016 samsung washer makes loud noise while in rinse, spin cycle..what can this be? and what i can do to fix this…</p>
<p>⟐ Answer edited januari 22, 2026 at 12:08 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/713703/loud+noise+on+rinse+and+spin+cycle..what+can+I+do+to+fix+this</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/713703</guid>
<pubDate>Thu, 22 Jan 2026 12:08:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: washing machine doesn’t work, only hums]]></title>
<description><![CDATA[<p>My washing machine doesnt work, has a humming sound when I start a washing cycle. But it does work on Rinse and spin cycle. The machine fills water too during spin and rinse cycle. Anyone knows what’s going on? I’m debating on whether to repair or replace. The machine is out of warranty.</p>
<p>⟐ Commented juli 05, 2020 at 0:13 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/644272/washing+machine+doesn%E2%80%99t+work,+only+hums</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/644272</guid>
<pubDate>Sun, 05 Jul 2020 00:13:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: washing machine drains but will not go in spin cycle]]></title>
<description><![CDATA[<p>washing machine drains but will not go in spin cycle</p>
<p>⟐ Answer accepted januari 14, 2018 at 22:29 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/447614/washing+machine+drains+but+will+not+go+in+spin+cycle</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/447614</guid>
<pubDate>Sun, 14 Jan 2018 22:29:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: The steam treat function is locked. Is there a way to reset this?]]></title>
<description><![CDATA[<p>How do I unlock this function?  I do wish to have all of my loads steam treated.</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/853575/The+steam+treat+function+is+locked.+Is+there+a+way+to+reset+this</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/853575</guid>
<pubDate>Sat, 08 Jun 2024 11:25:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Why my washing machine stopped cycling]]></title>
<description><![CDATA[<p>Why my washing machine stopped cycling</p>
<p>⟐ Commented mei 30, 2023 at 23:07 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/794391/Why+my+washing+machine+stopped+cycling</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/794391</guid>
<pubDate>Tue, 30 May 2023 23:07:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Spin cycle is loud like a train]]></title>
<description><![CDATA[<p>Washes fine but very loud on spin started a week ago</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/705750/Spin+cycle+is+loud+like+a+train</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/705750</guid>
<pubDate>Wed, 15 Sep 2021 17:22:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: My washing machine shuts down after locking the door]]></title>
<description><![CDATA[<p>after choosing the washing program and closing the door the washing machine just shuts down ,even the door is locked and i can’t turn it on again till the door is unlocked</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/592611/My+washing+machine+shuts+down+after+locking+the+door</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/592611</guid>
<pubDate>Mon, 23 Sep 2019 13:51:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: Drain Pump Stopped working, Replaced, worked for one load, broke]]></title>
<description><![CDATA[<p>It seemed like a clear-cut issue, that the machine was not draining, and hose was not clogged. I purchased a new drain pump motor and replaced it. It worked fine for one load of laundry and now has the same issue: the washer doesn’t drain and stops before the rinse cycle.</p>
<p>Would greatly appreciate any advice.</p>
<p>⟐ Commented augustus 17, 2019 at 17:30 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/585139/Drain+Pump+Stopped+working,+Replaced,+worked+for+one+load,+broke</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/585139</guid>
<pubDate>Sat, 17 Aug 2019 17:30:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung B1445A Washing Machine: small leak where top panel joins two side panels]]></title>
<description><![CDATA[<p>have small water leak from the seam between  top and two side panels</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/334260/small+leak+where+top+panel+joins+two+side+panels</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/334260</guid>
<pubDate>Wed, 31 Aug 2016 14:42:41 -0700</pubDate>
</item>
</channel>
</rss>
