<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Olympus Camera&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Olympus_Camera?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Olympus Camera&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 11 Aug 2026 13:32:20 -0700</pubDate>
<item>
<title><![CDATA[Olympus OM-D E-M10: De lens is geblokkeerd - The lens is blocked]]></title>
<description><![CDATA[<p>Bij het inschakelen gaat de lens 3x in en uit, maar blijft dan geblokkeerd. Geen beeld, geen sluiter mogelijk. Reset gedaan, batterij reeds eruit gehaald. Niets helpt. Blijkbaar zit het probleem in de lens zelf, want met een andere lens lukt het wel. Lens = M.zuiko 14-42 mm.</p>
<p>The lens is blocked  When switching on, the lens goes in and out 3x, but then remains blocked. No image, no shutter possible. Reset done, battery already removed. Nothing helps. Apparently the problem is in the lens itself, because it works with a different lens. Lens = M.zuiko 14-42 mm.<br /></p>
<p>Can anyone help me ????</p>
<p>⟐ Answered oktober 11, 2025 at 15:36 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/578044/De+lens+is+geblokkeerd+-+The+lens+is+blocked</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/578044</guid>
<pubDate>Sat, 11 Oct 2025 15:36:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Camera: Sluitergordijn kapot OMD EM- 10]]></title>
<description><![CDATA[<p>hoe vervang ik sluitergordijn OMD EM - 10</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/849873/Sluitergordijn+kapot+OMD+EM-+10</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/849873</guid>
<pubDate>Fri, 17 May 2024 09:12:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Camera: Kunnen jullie de Olympus CL2500 nog repareren..?]]></title>
<description><![CDATA[<p>Van deze camera is één van de accu contacten afgebroken door metaal moeheid. Het is het contact voor de AA batterijen 1,5 volt welke is afgebroken.</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/775930/Kunnen+jullie+de+Olympus+CL2500+nog+repareren..</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/775930</guid>
<pubDate>Wed, 29 Mar 2023 04:48:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus C-765: geen beeld en camera reageert niet op bediening na dat deze aangezet]]></title>
<description><![CDATA[<p>Na het aanzetten van de camera gaat de lens naar buiten en daarna gebeurd er niets meer, als ik een tik geeft tegen de zij kant van de lens doet hij het wel weer.</p>
<p>Zit er daar een sensor?</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/533868/geen+beeld+en+camera+reageert+niet+op+bediening+na+dat+deze+aangezet</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/533868</guid>
<pubDate>Wed, 05 Dec 2018 04:52:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus E-Pl1: Sluiter maakt schrapend geluid]]></title>
<description><![CDATA[<p>Sinds enige tijd maakt de sluiter een schrapend geluid, kan ik hier iets aan doen.</p>
<p>Schoonmaken ?</p>
<p>Hoe kan ik het gordijn gesloten hebben zodat ik kan zien of er stof .... opzit,  en met een blaasbalgje kan reinigen.</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/502839/Sluiter+maakt+schrapend+geluid</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/502839</guid>
<pubDate>Mon, 23 Jul 2018 12:51:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Camera: Repair/replace card door Olympus E-510 DSLR]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/PAFgBFqtuyWccwQQ.standard" width="282" height="191" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/PAFgBFqtuyWccwQQ.huge&quot;, '', 'width=1600,height=1084')" /></div>
<p>The card door on my Olympus E-510 DSLR has lost the two tabs that engage the catch that keep the door closed. Looking for information on how to replace the door.  Thanks!</p>
<p>⟐ Commented juni 02, 2026 at 19:02 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/61762/Repair-replace+card+door+Olympus+E-510+DSLR</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/61762</guid>
<pubDate>Tue, 02 Jun 2026 19:02:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Camera: camera won't turn off while battery is insterted]]></title>
<description><![CDATA[<p>My camera has decided that it will not turn off as long as I have the battery inserted. This started about 1.5 weeks ago (no dropping or damage happened), and still continues. I have to remove the batter to ensure that it turns off and not to drain the battery. This is the OM-D Mark 5 II model, just 14 months old. 2 months past warrenty which is killing me.</p>
<p>⟐ Answered december 25, 2024 at 13:15 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/353864/camera+won&#039;t+turn+off+while+battery+is+insterted</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/353864</guid>
<pubDate>Wed, 25 Dec 2024 13:15:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Camera: Battery Door Plastic Slider Broke on my Olympus Stylus 820]]></title>
<description><![CDATA[<p>Hoping someone out there will be able to help me with this. The plastic slider of the battery door on my Olympus Stylus 820 broke. I ordered a replacement through Olympus and received it the next day. Unfortunately, it did not come with directions. I called the customer service number and was told I cannot have the instructions to install it myself. I need to send it in to them to repair even though they sold me the part (go figure!).</p>
<p>I've now got a new battery cover that I can't install, a useless camera and a bad taste left over from dealing with Olympus customer service.</p>
<p>Can anyone tell me how to install the battery cover?</p>
<p>Thanks to anyone who is willing to assist.</p>
<p>Jano</p>
<p>⟐ Answered mei 12, 2024 at 6:43 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/17372/Battery+Door+Plastic+Slider+Broke+on+my+Olympus+Stylus+820</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/17372</guid>
<pubDate>Sun, 12 May 2024 06:43:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Stylus 300: Camera powers down unexpectedly]]></title>
<description><![CDATA[<p>The camera is several years old. When it is powered on, it frequently shuts down, retracting the lens. This sometimes happens within seconds of being turned on, other times it lasts long enough to take photos. I replaced the battery, then opened the camera up and cleaned the electrical contacts. No luck. Any ideas?</p>
<p>⟐ Commented januari 28, 2022 at 13:42 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/9150/Camera+powers+down+unexpectedly</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/9150</guid>
<pubDate>Fri, 28 Jan 2022 13:42:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus OM-D E-M10 Mark II: Dispaly cable Olympus OM-D E-M10 Mark II]]></title>
<description><![CDATA[<p>The tilt display works in some positions, but in most - not.</p>
<p>⟐ Answered oktober 25, 2019 at 7:25 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/554371/Dispaly+cable+Olympus+OM-D+E-M10+Mark+II</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/554371</guid>
<pubDate>Fri, 25 Oct 2019 07:25:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus E-Pl1: set T/M/J every accu change]]></title>
<description><![CDATA[<p>every time i change the Accu i have to set the time and date agan. Is there an Button cell or an  buffer condensator i can change? it seems like it is a comman problem on this moddel but no one has a fix for it so far.</p>
<p>⟐ Answered juli 25, 2017 at 20:10 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/272039/set+T-M-J+every+accu+change</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/272039</guid>
<pubDate>Tue, 25 Jul 2017 20:10:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Camera: Olympus OM-D E-M10 front curtain flutters?]]></title>
<description><![CDATA[<p>Hi everyone,</p>
<p>I got this problem with my EM 10.  When the camera is off, the front shutter curtain stays shut (normally it is open).  When I turned the camera on, the curtain will flickers for a few times (make some noise) then it stays shut and the camera will shut itself off.</p>
<p>I can't access the LCD menu and cannot take a picture.</p>
<p>Anyone know how i solve this?</p>
<p>It is similar to this problem on youtube -&gt; <a href="https://www.youtube.com/watch?v=dhmzvbxOOqY" title="https://www.youtube.com/watch?v=dhmzvbxOOqY">https://www.youtube.com/watch?v=dhmzvbxO...</a></p>
<p>⟐ Commented oktober 28, 2017 at 9:06 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/209796/Olympus+OM-D+E-M10+front+curtain+flutters</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/209796</guid>
<pubDate>Sat, 28 Oct 2017 09:06:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Evolt E510: Out of focus pictures]]></title>
<description><![CDATA[<p>I've cleaned the lenses and camera, tried 2 different Compact Flash cards, two different lenses, and tried numerous settings and lighting situations.   I've updated the firmware, as well, but the situation remains.  In every case, the camera appears to take the picture in focus but when I look at the saved photos, they are &quot;fuzzy&quot;.  When I look at the photos on the PC, they are &quot;Fuzzy&quot;, as well.  Any ideas?</p>
<p>⟐ Answered maart 09, 2017 at 16:58 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/269422/Out+of+focus+pictures</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/269422</guid>
<pubDate>Thu, 09 Mar 2017 16:58:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus FE-210: Why all my out door pictures turn out white and washed out?]]></title>
<description><![CDATA[<p>My display shows good color and sharp picture.</p>
<p>Indoor picture using flash gets good picture.</p>
<p>Ouidoor movie picture works fine also.</p>
<p>All outdoor still pictures with any setting mode turn up white, washed out with very little details.</p>
<p>⟐ Answer accepted juni 10, 2015 at 18:44 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/184749/Why+all+my+out+door+pictures+turn+out+white+and+washed+out</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/184749</guid>
<pubDate>Wed, 10 Jun 2015 18:44:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Stylus Tough-6000: led screen not coming on]]></title>
<description><![CDATA[<p>led screen wont come on</p>
<p>⟐ Commented april 02, 2017 at 18:02 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/256987/led+screen+not+coming+on</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/256987</guid>
<pubDate>Sun, 02 Apr 2017 18:02:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus 850SW: problem with color and auto focus]]></title>
<description><![CDATA[<p>turned camera on,after being left for several months. The color is not true and pictures are out of focus. Tried the reset and it does nothing. Can't find anything on the menu, that restores the true colors.</p>
<p>Can you help pls?</p>
<p>⟐ Commented september 09, 2015 at 13:03 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/240196/problem+with+color+and+auto+focus</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/240196</guid>
<pubDate>Wed, 09 Sep 2015 13:03:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus OM-D E-M10: rotary plastic lever for the start switch of the OMD E-M5 mark 1]]></title>
<description><![CDATA[<p>Hi.</p>
<p>I'm looking without success for the plastic part serving as a rotary lever for the start switch of the Olympus OM D E-M5 mark 1. Many thanks,</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_04_22_Num_2022" class="header">Update (04/22/2022)</h3></div>
<p>Here's the note I sent to Olympus:</p>
<p>I'm a French customer and have OMD E-M5 Mark 1, OMD E-M5 mark2, a large Olympus flash and 3 Olympus zooms. Although ALWAYS handling the start lever of my M5 mark1 with great care, this plastic lever has just broken into 5 pieces, without warning ...</p>
<p>I'm convinced that this lever is simply clipped on the metal axis of the switch. Using a high quality industrial binocular, I cannot understand how the plastic lever can ensure rotation of the axis. To open the M5mark 1 does not scare me. I'm assured that in the United States, parts of the M5 mark1 are still available.</p>
<p>Can you provide me with this plastic lever? Cordially,</p>
<p>SENDED TO: <a href="https://learnandsupport.getolympus.com/support/e-m5#section-support-form" rel="nofollow noopener noreferrer">OM-D E-M5</a></p>
<p>⟐ Commented januari 27, 2026 at 21:41 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/729975/rotary+plastic+lever+for+the+start+switch+of+the+OMD+E-M5+mark+1</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/729975</guid>
<pubDate>Tue, 27 Jan 2026 21:41:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Camera: Message on my screen says "write protect."]]></title>
<description><![CDATA[<p>I have an Olympus SP-720 UZ camera.  When I turn it on, I get a message on my screen that reads &quot;write protect&quot;.  Can someone give me an idea what is going on.  It goes away when I take the SD card out, but there isn't enough memory in my camera to take pictures without it.</p>
<p>⟐ Answered oktober 23, 2025 at 1:23 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/416925/Message+on+my+screen+says+%22write+protect.%22</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/416925</guid>
<pubDate>Thu, 23 Oct 2025 01:23:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus Camera: FE-340 will not stay on.]]></title>
<description><![CDATA[<p>I have replaced the battery.  When powered &quot;on,&quot; the zoom lens moves back and forth, then remains &quot;zoomed.&quot;  The LCD screen remains black throughout the process--a couple of seconds--and the camera shuts off.</p>
<p>⟐ Commented mei 06, 2024 at 21:06 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/496774/FE-340+will+not+stay+on.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/496774</guid>
<pubDate>Mon, 06 May 2024 21:06:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Olympus 850SW: LCD screen is black]]></title>
<description><![CDATA[<p>my cameras lcd screen is black i cant see anything it still takes photos tho but i cant see them?</p>
<p>⟐ Commented april 27, 2020 at 15:54 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/319140/LCD+screen+is+black</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/319140</guid>
<pubDate>Mon, 27 Apr 2020 15:54:49 -0700</pubDate>
</item>
</channel>
</rss>
