<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Microsoft Surface Pro 7 Plus&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Microsoft_Surface_Pro_7_Plus?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Microsoft Surface Pro 7 Plus&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 05 Sep 2026 12:35:28 -0700</pubDate>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Surface type cover not powering on and connecting to the computer]]></title>
<description><![CDATA[<p>So…I currently use a surface pro 7+ for everyday and all of a sudden my keyboard stopped working (For context here’s a few things that are normal):</p>
<ul><li>Surface turns on</li><li>Surface reaches login screen</li><li>Surface logs in and is on home screen</li><li>Surface is in UEFI bios</li><li>Surface is in Advanced startup options.</li></ul>
<p>In none of these scenarios does the keyboard work. No lights are on. No signs of life. However after a reset of windows it does work but then small things do trigger it to stop working again.</p>
<p>I have tried literally everything from cleaning the contacts to even (repeatedly) turn on and off the type cover port in the UEFI bios with absolutely 0 luck at all.</p>
<p>Pls help as this is a machine used on an everyday basis.</p>
<p>Thanks.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_10_04_Num_23" class="header">Update (10/04/23)</h3></div>
<p>So, after going back and forth with Microsoft, the only solution they had was to send me a new keyboard, which now works fine.</p>
<p>⟐ Commented oktober 11, 2023 at 1:57 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/723907/Surface+type+cover+not+powering+on+and+connecting+to+the+computer</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/723907</guid>
<pubDate>Wed, 11 Oct 2023 01:57:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Would I be able to use the pro 7 screen on a pro 7+?]]></title>
<description><![CDATA[<p>Would I be able to use the pro 7 screen on a pro 7+ ?</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/764958/Would+I+be+able+to+use+the+pro+7+screen+on+a+pro+7+</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/764958</guid>
<pubDate>Wed, 18 Jan 2023 17:48:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Is the battery replaceable on the surface pro 7 plus]]></title>
<description><![CDATA[<p>What kind of connection is it? And how does it connect to the logic board?</p>
<p>⟐ Answered oktober 04, 2025 at 16:12 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/910805/Is+the+battery+replaceable+on+the+surface+pro+7+plus</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/910805</guid>
<pubDate>Sat, 04 Oct 2025 16:12:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Can I replace or extend the RAM?]]></title>
<description><![CDATA[<p>Is it possible to extend the RAM capacity in the Surface Pro 7+ ?</p>
<p>⟐ Commented maart 17, 2023 at 2:01 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/762219/Can+I+replace+or+extend+the+RAM</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/762219</guid>
<pubDate>Fri, 17 Mar 2023 02:01:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Thermal paste on SSD?]]></title>
<description><![CDATA[<p>The SSD replacement kit contains a tube of thermal paste. Should i really use that? If so: on both sides?</p>
<p>⟐ Commented oktober 20, 2025 at 2:28 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/922609/Thermal+paste+on+SSD</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/922609</guid>
<pubDate>Mon, 20 Oct 2025 02:28:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: I lost Simcard tray, how can I order a new one?]]></title>
<description><![CDATA[<p>I lost the sim card tray, how can I order a new one?</p>
<p>⟐ Answered september 17, 2025 at 8:39 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/917642/I+lost+Simcard+tray,+how+can+I+order+a+new+one</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/917642</guid>
<pubDate>Wed, 17 Sep 2025 08:39:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Does the original Pro battery repair kit apply to Pro 7 Plus?]]></title>
<description><![CDATA[<p>By chance does this repair kit help replacement with the Surface Pro 7 Plus?</p>
<p>⟐ Answered maart 26, 2024 at 5:10 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/838379/Does+the+original+Pro+battery+repair+kit+apply+to+Pro+7+Plus</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/838379</guid>
<pubDate>Tue, 26 Mar 2024 05:10:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Error message: "Couldn't find bootable..." but SSD and OP system is OK]]></title>
<description><![CDATA[<p>Hi,</p>
<p> </p>
<p>I would need your advice. I have a Surface Pro 7+ (core i7, 32GB, 1TB SSD) that was bought 2,5 years ago. A month ago it started to have blue screen than, it restarted and after that worked fine for a few days. After that it had the same error message and restarted again and worked again for a few days. However at once, after restarting I had the message</p>
<div class="clearer"></div><div class="headerContainer"><h2 id="Section__Couldn_t_find_a_bootable_operating_system" class="header">&quot;Couldn't find a bootable operating system&quot;</h2></div>
<p> </p>
<p>I searched on the internet and after several attempt to recover the computer or unlock the bitlocker I stated that probably my SSD is dead, I have to replace it. I put the device aside for a few weeks and when I checked it, it is worked again fine. I could log in, windows loaded perfectly several times, I could read and write the SSD (of course I made a backup save to have all my important files), but now it came back again to the same error message: couldn't find a bootable... It is important, that not the windows is broken as when I try to make a recovery with a surface image, it doesn't find the SSD itself, so I had the hint that maybe it is a hardver, SSD connection issue. While I could login into the windows and it worked fine I could also checked and repair corrupted files, software updates and SSD maintenance. OP system should work properly.</p>
<p>Therefore, I bought a simple NVMe, PCI-e (M.2, 2230) SSD enclosure and attached the SSD to another computer. I could read and write the SSD. As I put back to the Surface Pro 7+, it had the same error message and don't let recovery with an image because don't find the SSD. This is consequent, every time I test it (I did it 5-7 times), it remains the same. Externally I can read and write the SSD and internally there is no access. So I think that finally not SSD is broken, but the connection within the computer?</p>
<p> </p>
<p>Do you have any idea how could I repair it or test it more? What could be a solution? Is there any other software solution? Is there any replacement part for it or it is integrated into the motherboard... I don't know.</p>
<p> </p>
<p>Thank you in advance!</p>
<p> </p>
<p>Br,</p>
<p> </p>
<p>Tibor</p>
<p>⟐ Commented december 12, 2023 at 7:54 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/827762/Error+message:+%22Couldn&#039;t+find+bootable...%22+but+SSD+and+OP+system+is+OK</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/827762</guid>
<pubDate>Tue, 12 Dec 2023 07:54:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Battery problems, not keeping it's charge, and sluggish performance]]></title>
<description><![CDATA[<p>This happened yesterday, where my Surface started to become painfully slow all of a sudden after a restart. It also was not keeping it's charge; it was plugged in but sank from 50% to 20% overnight. I think this may be a battery issue, battery failure or a charger failure, or something else. I just want to have this confirmed so I know what is going on and can get it repaired quickly.<br /><br />I have drained it to 5 percent, charged it to 50% and did it again, so it's kinda my fault</p>
<p>⟐ Answered oktober 26, 2023 at 8:01 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/821023/Battery+problems,+not+keeping+it&#039;s+charge,+and+sluggish+performance</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/821023</guid>
<pubDate>Thu, 26 Oct 2023 08:01:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Compatibility of pro7 and pro5 screens]]></title>
<description><![CDATA[<p>Hello from Japan. Sorry if my English is poor.</p>
<p>I recently succeeded in replacing the inflated battery in my surfacepro5 intact, but (foolishly) I am about to get my hands on a junk pro7+ next. So my question is, is the screen of the pro5 compatible with the pro7 in order to use it for operational testing, etc.? I know that the location of the terminals may be different depending on the production lot.</p>
<p>⟐ Answer accepted oktober 11, 2022 at 22:36 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/749173/Compatibility+of+pro7+and+pro5+screens</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/749173</guid>
<pubDate>Tue, 11 Oct 2022 22:36:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Are there any replaement screens fo Suface Pro 7 Plus]]></title>
<description><![CDATA[<p>I cannot find a replacement screen for my tablet. does anyone have a part number or link for one.</p>
<ul><li><strong>Serial number:</strong> 007793213553</li><li><strong>Surface model:</strong> Surface Pro 7+ Model 1960 i7</li><li><strong>SAM:</strong> 12.206.139.0</li><li><strong>UEFI:</strong> 16.101.141.0</li><li><strong>Touch driver:</strong> 5.141.139.0</li><li><strong>Wi-Fi driver:</strong> 22.40.0.7</li><li><strong>App Version:</strong> 61.1034.139.0</li></ul>
<p>Thank you<br /></p>
<p>⟐ Answered maart 05, 2022 at 15:21 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/722115/Are+there+any+replaement+screens+fo+Suface+Pro+7+Plus</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/722115</guid>
<pubDate>Sat, 05 Mar 2022 15:21:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Bluish green and yellow lines on display]]></title>
<description><![CDATA[<p>These lines are appearing on the UEFI mode as well but not appearing on the windows installation setup page.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/vXDHXYJNf4R1Mgtu.standard" width="282" height="158" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/vXDHXYJNf4R1Mgtu.full&quot;, '', 'width=1599,height=899')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DZecHo1dZUqtCnMJ.standard" width="282" height="158" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DZecHo1dZUqtCnMJ.full&quot;, '', 'width=1280,height=720')" /></div>]]></description>
<link>https://nl.ifixit.com/Answers/View/917015/Bluish+green+and+yellow+lines+on+display</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/917015</guid>
<pubDate>Sat, 13 Sep 2025 09:23:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Problem replacing digitizer screen]]></title>
<description><![CDATA[<p>We are having problems just getting started trying to replace the digitizer screen on a Microsoft Surface 7+ Pro.</p>
<p>Although the documentation keeps referring to running the SDT software and choosing &quot;Repair setup and validation&quot; and entering TDM Replacement Mode.</p>
<p>Initially, we could not find this option on any version of the SDT software that we could find. We did finally find some software that had a technician mode that did allow for TDM Replacement Mode.</p>
<p>Now, however, we are getting the error:</p>
<blockquote class="featured"><p>Running Test: The type initializer for 'NCPTransport.AccessNcpTransportFactory' threw an exception.</p></blockquote>
<p>With no further error information. We've updated drivers on the computer, but we're still getting the error. We can't find anything on the internet about this error or how to resolve it.</p>
<p>Any idea what this means and how we can get around this? We haven't even started the hard part yet, but we seem stymied by this software error.</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/836375/Problem+replacing+digitizer+screen</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/836375</guid>
<pubDate>Sun, 11 Feb 2024 14:32:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: No Title (You should edit this question)]]></title>
<description><![CDATA[<p>Surface pro4 UEFI blocca la type covert port</p>
<p>⟐ Commented oktober 10, 2023 at 1:03 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/817625/No+Title+(You+should+edit+this+question)</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/817625</guid>
<pubDate>Tue, 10 Oct 2023 01:03:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 7 Plus: Is it possible to assemble an i5 model with a cooling fan?]]></title>
<description><![CDATA[<p>Can the heat sink with cooling fan for i7 be replaced with a heat sink of a lower model to assemble an i5 model with cooling fan?</p>
<p>Is there a possibility of running out of control terminal ports?</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/751415/Is+it+possible+to+assemble+an+i5+model+with+a+cooling+fan</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/751415</guid>
<pubDate>Wed, 12 Oct 2022 22:38:28 -0700</pubDate>
</item>
</channel>
</rss>
