<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Microsoft Surface Pro 5&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Microsoft_Surface_Pro_5?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Microsoft Surface Pro 5&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 15 Aug 2026 13:11:29 -0700</pubDate>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Bad battery, need to replace]]></title>
<description><![CDATA[<p>Hello. I think I may need to replace the battery in my Surface pro 2017 if it gets any worse. Two years after I bought it I only get 3 hours of battery life. I see you have a surface pro 4 battery replacement video but I can’t find any specifically for Surface Pro 2017. Do the video and the tools for the Pro 4 also work for the Pro 2017? Any advice would be appreciated. Thanks!</p>
<p>⟐ Commented december 28, 2020 at 18:46 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/573168/Bad+battery,+need+to+replace</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/573168</guid>
<pubDate>Mon, 28 Dec 2020 18:46:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Do I need to change wifi antenna assembly?]]></title>
<description><![CDATA[<p>I replaced the battery and while opening up the screen, I tore off the wifi antennas from its assembly. However, the wifi still works after putting it back together.</p>
<p>The one thing I am confused about is, on this model, the antenna do not connect to anything on the motherboard, or am I mistaken?</p>
<p>There is a little metal piece on the bottom of the assembly (3rd pic) which connects to the motherboard but that piece does not attach to the antenna whatsoever.</p>
<p>I have attached some photos of what the antennas and the assembly look like in my case.</p>
<p>Thank You in Advance!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2wYRWLnToPdEQsYu.standard" width="169" height="225" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2wYRWLnToPdEQsYu.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2D6t6Ik2QOiK1LAw.standard" width="169" height="225" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2D6t6Ik2QOiK1LAw.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/TIcJs5ciOUVTBa6G.standard" width="169" height="225" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/TIcJs5ciOUVTBa6G.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented april 26, 2026 at 11:24 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/735358/Do+I+need+to+change+wifi+antenna+assembly</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/735358</guid>
<pubDate>Sun, 26 Apr 2026 11:24:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Surface Pro 5 3rd touch failure. Screen replacement didn't fix the los]]></title>
<description><![CDATA[<p>Hello everyone!</p>
<p>I am so lost and really don't know what to do anymore. My customers Surface Pro 5 has lost it's touch function after a windows 10 update. Also there is no touch input within the UEFI bios.</p>
<p>Since I am a technician, I installed a known good tester display with new cables and a working touch board. Nothing.</p>
<p>Got a new display from AliExpress with a new touch controller, it worked until the first reboot. Aaaaand it's gone.</p>
<p>I did check the AliExpress display on a tester surface pro 5 and it worked prior to installing it on my customers device.</p>
<p>After I installed it on my customers SP5 it no longer worked.</p>
<p>I feel like this surface pro 5 has a habit of frying display touch controllers. Checked the board for any heat spots or water damage but there is nothing.</p>
<p>All the voltages are fine and no capacitors or resistors are bad.</p>
<p>So what the hell is going on here? Do you guys have any idea what the issue could be?</p>
<p>Reinstalled everything as well btw and tried win 11 with no luck.</p>
<p>Had a similar issue with my personal Surface Pro 5 and had to replace the motherboard.</p>
<p>This is how ever a 1TB i7 board and it would a shame to trash it.</p>
<p>Best regards</p>
<p>⟐ Commented november 30, 2025 at 14:33 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/839495/Surface+Pro+5+3rd+touch+failure.+Screen+replacement+didn&#039;t+fix+the+los</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/839495</guid>
<pubDate>Sun, 30 Nov 2025 14:33:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Pro 5 1796 not detecting new battery.]]></title>
<description><![CDATA[<p>Hello all, I recently replaced the battery in my Surface Pro 5 1796, and upon powering it back on, Windows shows no battery present in the tablet. There is no battery icon in the taskbar, no battery settings in the Settings app, and upon checking device manager, it says that the Surface Battery is not installed in the computer.</p>
<p>Despite this, the battery is still sending power out to the system. I can unplug and use the device just fine, but when the battery dies, it immediately shuts off. No low battery warning, sleep state, or low battery icon from the UEFI when you try to power it up. Just a black screen.</p>
<p>This tells me that the battery is seated correctly in its spot, but something within the software is messing it up. I've tried reinstalling drivers, doing windows update, and performing a Surface Diagnostics Test, but to no avail. I have yet to try a full re installation of Windows.</p>
<p>If someone has any tips or solutions to this, please let me know. Thanks.</p>
<p>⟐ Answered december 14, 2023 at 11:16 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/745812/Pro+5+1796+not+detecting+new+battery.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/745812</guid>
<pubDate>Thu, 14 Dec 2023 11:16:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Heat Gun/Blower for Screen Replacement]]></title>
<description><![CDATA[<p>I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.</p>
<p>I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below),  which I thought could be helpful with other projects also.</p>
<p><a href="https://www.jaycar.co.nz/3-in-1-function-heat-blower-and-soldering-iron/p/TH1604" rel="nofollow noopener noreferrer" title="https://www.jaycar.co.nz/3-in-1-function-heat-blower-and-soldering-iron/p/TH1604">https://www.jaycar.co.nz/3-in-1-function...</a></p>
<p>Has anyone had any experience using this type of &quot;heat blower&quot;? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.</p>
<p>Thanks in advance for your help.</p>
<p>⟐ Commented januari 26, 2023 at 5:49 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/476251/Heat+Gun-Blower+for+Screen+Replacement</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/476251</guid>
<pubDate>Thu, 26 Jan 2023 05:49:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Can't move my pick past a crack.]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/TkpIJjQDrIwknfWK.standard" width="170" height="225" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/TkpIJjQDrIwknfWK.huge&quot;, '', 'width=904,height=1200')" /></div>
<p>Started on the right speaker, which then cracked. So I moved to the left speaker and went down, and came across an existing crack which bent up, preventing my pick from moving the rest of the way. The same thing happened when I tried going up. So i'm pretty much stuck at this point. Any tips on continuing past where i'm at right now?</p>
<p>⟐ Commented april 12, 2022 at 21:09 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/728578/Can&#039;t+move+my+pick+past+a+crack.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/728578</guid>
<pubDate>Tue, 12 Apr 2022 21:09:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Replaced Screen. Touch and Pen Problems]]></title>
<description><![CDATA[<p><em>I dropped my Surface Pro 5.  I ordered and received a new screen through Amazon. For a while, things were good, but then touch and pen functions started to deprecate.  I did not drop it again, but I think I may have disturbed something when I replaced the not so protective but cute protective case with a more rugged (and expensive - worth it!) Urban Gear case.</em></p>
<p><strong><em>I reopened it.  I cleaned out some of the adhesive, mainly from the top where there is some copper (antenna?)   This seemed to give me more consistent pen operation.  I am thinking about removing and reinstalling the screen now that I know what to do.  Maybe I will recover something that I missed on the first pass in the process.</em></strong></p>
<p><em>I disabled the two HID touch screen entries in Device Manager, restarted, enabled, restarted.  At first, I saw the little gray circles, but the screen cycled off and on a few times.  They disappeared.</em><br /><br /><strong><em>Do you think uninstalling the drivers will help or harm?  I assume this would force Windows (11) to look for drivers again?</em></strong><br /><br />I hope it is not a faulty screen, since I am sure my return opportunity is gone.</p>
<p>⟐ Answered maart 05, 2022 at 21:33 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/723889/Replaced+Screen.+Touch+and+Pen+Problems</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/723889</guid>
<pubDate>Sat, 05 Mar 2022 21:33:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Surface Tcon Device cannot start (STATUS_DEVICE_POWER_FAILURE)]]></title>
<description><![CDATA[<p>Replaced battery and screen on Surface Pro 5. After reassembling I powered on the device and started up ok, but a portion of the screen wasn’t responding. to touch. I shut it down and disassembled to check my connections but when I did I removed one of the connectors improperly. This damaged the pins slightly. I was able to gently bend them into place and when I pushed the ribbon cable into it seemed to connect in just fine. Removing the ribbon cable and inspecting the pins again looks ok to my eyes, but when I power on the device there is no backlight, the microsoft logo flashes a couple times and the display goes black. Connecting to a external display shows the device powered on just fine. I’ve checked all my other connections and they seemed fine. I’m stuck looking at the connector I damaged but it too looks like it should be working still. Anyone have a schematic or can at least tell me which ribbon cable provides power (left or right) to the display.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/sVAUe6GonBMqEkQU.standard" width="282" height="211" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/sVAUe6GonBMqEkQU.full&quot;, '', 'width=640,height=480')" /></div>
<p>⟐ Answered mei 17, 2026 at 0:55 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/677687/Surface+Tcon+Device+cannot+start+(STATUS_DEVICE_POWER_FAILURE)</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/677687</guid>
<pubDate>Sun, 17 May 2026 00:55:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Replaced Battery, this is what I got..]]></title>
<description><![CDATA[<p>Was wondering what I broke here? I was very careful and it seemed to be okay when I replaced the battery and reassembled it.</p>
<p>The screen is not cracked, but I was wondering if it was a connection issue. However, why would just a strip display like this?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Tr52FWU1OFNZ1lGS.standard" width="102" height="225" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Tr52FWU1OFNZ1lGS.huge&quot;, '', 'width=540,height=1200')" /></div>
<p>⟐ Answered juli 06, 2023 at 11:36 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/799474/Replaced+Battery,+this+is+what+I+got..</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/799474</guid>
<pubDate>Thu, 06 Jul 2023 11:36:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Can I replace a pro 5 lcd with a pro 4 lcd?]]></title>
<description><![CDATA[<p>Can I replace a pro 5 lcd with a pro 4 lcd?</p>
<p>⟐ Commented mei 16, 2023 at 8:52 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/465760/Can+I+replace+a+pro+5+lcd+with+a+pro+4+lcd</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/465760</guid>
<pubDate>Tue, 16 May 2023 08:52:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Touchscreen only works when touching the case]]></title>
<description><![CDATA[<p>I bought an used SP5 and replaced the screen. All went perfect and no issue seemed to be present. But after using it more, I found a problem with the touch recognition. I can only use my finger to interact while touching the Metall case of the SP5, when laying it on the table (or any other surface) it won't recognize the touch input. I tried every other troubleshooting tip (reinstalling drivers, firmware, resting or setting the calibration etc).</p>
<p>I do have a screen protector on the screen. Might this be the problem? Or do I have to open the device again? Maybe there's some current acting as phantom touch on the whole screen? Magnetic interference? Surface pen works flawless.</p>
<p>⟐ Commented oktober 12, 2022 at 4:40 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/751141/Touchscreen+only+works+when+touching+the+case</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/751141</guid>
<pubDate>Wed, 12 Oct 2022 04:40:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: power connector port fault]]></title>
<description><![CDATA[<p>hi guys,</p>
<p>i observed that my surface pro 5 charging port is not charging due to physical damage to the port how can i fix it</p>
<p>⟐ Commented februari 16, 2023 at 17:46 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/769446/power+connector+port+fault</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/769446</guid>
<pubDate>Thu, 16 Feb 2023 17:46:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Microsoft firmware update failure caused touch input to stop working]]></title>
<description><![CDATA[<p>Looking to see if I can get any help from here, as Microsoft has been incredibly unhelpful. Here’s some background about the problem.</p>
<p>I have a Surface Pro (5th gen, model 1796) which has worked perfectly for years until a Surface firmware update (11.8.82.3838)  a few months ago, and after said update all pen and touch functionality ceased to work. After peering in device manager, it says that the Surface ME “device cannot start. (Code 10)” After some research, I found that an out of warranty replacement program was started a few years ago for Pro 4s with this exact issue, as once the firmware failed to apply, the Management Engine device had to be replaced. But since this is a Pro 5, Microsoft is telling me this has to be a hardware problem and I have to pay $450 USD to get a refurbished replacement out of warranty, which I’m not willing to do. If anyone’s interested, <a href="https://answers.microsoft.com/en-us/surface/forum/all/need-microsoft-response-surface-pro-5-2017/87bd33c4-8efa-466e-a23b-5b917a5f6b6c" rel="nofollow noopener noreferrer">here’s the Microsoft Community post I made.</a> It has the firmware information and my angry rant.</p>
<p>I’ve done a total reset, ran Surface Diagnostic tool, even did a Surface Recovery Image, reinstalled drivers, no dice. Touch does not work in UEFI either.</p>
<p>So, the question here— what are my options? Anyone with Microsoft device experience or knowledge of software options that could help would be appreciated. However, if anyone knows if this component is something that can be replaced for less that $450, that’d be fantastic too, though I’m pretty sure its attached to the motherboard.</p>
<p><strong>TD;DR:</strong> Surface firmware 11.8.82.3838 broke touch functionality on SP 1796, Microsoft wants $450 to replace a device they broke, and I’m looking for other options.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/hXLuxU4FDfu2UUl5.standard" width="198" height="225" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/hXLuxU4FDfu2UUl5.full&quot;, '', 'width=800,height=910')" /></div>
<p><strong>06/02/2021 Update:</strong> Microsoft told me no dice whatsoever, and said I could recycle the device for a credit towards a new Surface, which is only $110 USD and that’s just wasteful. Still looking for answers.</p>
<p>⟐ Edited by author juni 02, 2021 at 6:17 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/693431/Microsoft+firmware+update+failure+caused+touch+input+to+stop+working</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/693431</guid>
<pubDate>Wed, 02 Jun 2021 06:17:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Can I replace the kickstand?]]></title>
<description><![CDATA[<p>The hinge on the kickstand of my Surface Pro 5 broke and I’m trying to figure out if I can replace it, and if so, how?</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/599776/Can+I+replace+the+kickstand</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/599776</guid>
<pubDate>Sat, 02 Nov 2019 19:40:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: How to reset bios password]]></title>
<description><![CDATA[<p>How can I reset the bios password on my Surface Pro 5?</p>
<p>⟐ Commented augustus 01, 2019 at 19:21 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/581903/How+to+reset+bios+password</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/581903</guid>
<pubDate>Thu, 01 Aug 2019 19:21:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Screen calibration off after replacement, calibrating doesn't fix]]></title>
<description><![CDATA[<p>Replaced my screen &amp; digitizer assembly with one from ifixit, went smoothly enough and currently have my screen merely resting in the casing as when I texted the touch screen I get a response but it seems to be consistently off slightly from my pen tip. When I first start my Surface and get into my desktop screen, there are two touch points in the top corner of the screen until I touch the screen in any other location. I tried recalibrating the screen but that seemed to actually make it worse. Any ideas? No damage seen to either of the ribbons.</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/554699/Screen+calibration+off+after+replacement,+calibrating+doesn&#039;t+fix</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/554699</guid>
<pubDate>Tue, 12 Mar 2019 14:37:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Can I use 1796 screen to replace m1807 Surface pro screen?]]></title>
<description><![CDATA[<p>I have a customer needing a new screen for a surface model 1807</p>
<p><br /></p>
<p><strong>Surface Pro (5th Gen) with LTE Advanced - 256GB i5 8GB M1807</strong>   from the microsoft serial check.</p>
<p>My question is can i use the 1796 screen to replace it as I cant find one available for 1807.</p>
<p>Both being 5th Gen i think it would but I would like to know before ordering.</p>
<p>Cheers in advance. and thanks for the assistance.</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/542833/Can+I+use+1796+screen+to+replace+m1807+Surface+pro+screen</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/542833</guid>
<pubDate>Tue, 15 Jan 2019 17:14:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: I have no backlight or display after replacing the lcd/dig]]></title>
<description><![CDATA[<p>Replaced the entire display and now i get NOTHING. Don't know where the backlight chips/assembly is. There is no backlight or display, as best i can tell.  I have taken every (time consuming) precaution to prevent backlight damage, but I am open to it being a possibility. Any other solutions/suggestions appreciated.</p>
<p>⟐ Commented februari 03, 2018 at 12:49 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/452297/I+have+no+backlight+or+display+after+replacing+the+lcd-dig</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/452297</guid>
<pubDate>Sat, 03 Feb 2018 12:49:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: I would like to know the location of bios chip]]></title>
<description><![CDATA[<p>Hi</p>
<p>I would like to know the location of Bios chip of Microsoft surfce pro 5 model number 1796</p>
<p>Thanks</p>
<p>⟐ Commented juli 29, 2023 at 12:15 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/528640/I+would+like+to+know+the+location+of+bios+chip</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/528640</guid>
<pubDate>Sat, 29 Jul 2023 12:15:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Using Surface Pro 4 (1724) LCD screen to replace Surface Pro 5 (1796)]]></title>
<description><![CDATA[<p>Hello,</p>
<p>I have a Surface Pro 5 with a cracked screen. I also have a Surface Pro 4 LCD laying around and wanted to know whether I could use the LCD for Surface Pro 4 to replace this screen. The connectors look very similar in pictures, but I can’t open it up to find out as I would prefer to use what I have until I’m ready to spend $230 for a new screen...</p>
<p>⟐ Comment deleted februari 24, 2022 at 15:11 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/484866/Using+Surface+Pro+4+(1724)+LCD+screen+to+replace+Surface+Pro+5+(1796)</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/484866</guid>
<pubDate>Thu, 24 Feb 2022 15:11:47 -0700</pubDate>
</item>
</channel>
</rss>
