<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;MacBook Core Duo&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/MacBook_Core_Duo?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;MacBook Core Duo&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 02 Aug 2026 07:33:34 -0700</pubDate>
<item>
<title><![CDATA[MacBook Core Duo: Trackpad click button is jammed]]></title>
<description><![CDATA[<p>The click button on my trackpad has become jammed. It still functions but must be pressed hard to generate a click. Pressure on the palm rests will generate a mouse click because of this condition.</p>
<p>Is this likely to be something that removing the keyboard and cleaning might fix or would I need to replace the entire top cover, trackpad and keyboard?</p>
<p>Thanks,</p>
<p>⟐ Commented april 28, 2023 at 16:15 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/13339/Trackpad+click+button+is+jammed</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/13339</guid>
<pubDate>Fri, 28 Apr 2023 16:15:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: How to connect a magsafe to a solar panel]]></title>
<description><![CDATA[<p>Hi!</p>
<p>I recently bought a solar panel(Solar Gorilla), but to use it with my MacBook I need to fork out a large sum for the adapters. I have an old magsafe adapter, and several connector tips. Can I somehow connect the magsafe plug to a tip and get power without spending money?</p>
<p>Any help would be welcome!</p>
<p>Hazel</p>
<p>⟐ Answered april 27, 2017 at 3:06 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/7046/How+to+connect+a+magsafe+to+a+solar+panel</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/7046</guid>
<pubDate>Thu, 27 Apr 2017 03:06:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: DVD Drive spins up but doesn't read disc, then ejects disc]]></title>
<description><![CDATA[<p>the dvd drive accepts discs (both dvds and cds) it spins up like its gonna read the disc, then stops spinning then spins back up, it does this a couple times then it ejects the disc on its own. in disk utility the dvd drive still shows up, so the computer still recognizes the drive, whats wrong with it?</p>
<p>⟐ Answered maart 28, 2023 at 14:19 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/84885/DVD+Drive+spins+up+but+doesn&#039;t+read+disc,+then+ejects+disc</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/84885</guid>
<pubDate>Tue, 28 Mar 2023 14:19:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: My Keyboard and trackpad not working]]></title>
<description><![CDATA[<p>I recently changed my Macbook keyboard the entire topcase, but it is not working at all. I can turn on the machine using the power button on the keyboard and cannot use the keyboard.</p>
<p>Please advise.</p>
<p>⟐ Commented oktober 22, 2020 at 8:33 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/6174/My+Keyboard+and+trackpad+not+working</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/6174</guid>
<pubDate>Thu, 22 Oct 2020 08:33:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: MacBook Core Duo not working properly after internals were replaced]]></title>
<description><![CDATA[<p>I just finished doing some major computer repairs on a 2.0GHz MacBook Core Duo. About a week or two ago, my mother was using her MacBook while drinking coffee and ended up spilling a significant amount of it onto the top case of the open MacBook. She called me about it and I was able to obtain the MacBook that night to do some heavy duty cleaning.</p>
<p>I took the computer apart entirely and cleaned up all the coffee I could using 91% isopropyl alcohol. After reassembly, I tried to power it on, but it was no good. The MagSafe light would not illuminate when any power adapter was connected and the logic smelled a bit like burned plastic, so I determined it was a dead.</p>
<p>I purchased a used, working logic board on eBay a few days ago and transplanted that into a separate MacBook Core Duo that I obtained from my brother using the iFixIt repair guides. His logic board had died of natural causes and none of the internals had ever come into contact with fluids, so they were fully operational. The only internal component I used from the MacBook that had coffee spilled on it was the hard drive, but it was not damaged and was tested in an external enclosure, so it too was operational.</p>
<p>I finished reinstalling all the internal components today connected the MagSafe adapter. The light on the adapter came on this time and the battery indicator lights are blinking and rising, so the logic board is receiving power. Upon power up, the optical drive sounded, but it just kept cycling. I didn't hear the fans power up and all is silent, but the cycling optical drive. So I'm not sure what problem there may be now. Could someone provide some insight given the symptoms I've described? Let me know if you need to know more. Thank you so much, indispensable iFixIt community!</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section__Update_11_5_10_Repair_Log" class="header"><strong>Update - 11/5/10 Repair Log</strong></h3></div>
<p>After trying all the suggestions that <a href="http://www.ifixit.com/User/22332/rdklinc">rdklinc</a> provided, I compiled a log of my results in order to see if this issue could be further diagnosed. Here it is:</p>
<p>When powered on, the MacBook's optical drive and hard drive fire up, but the sleep light comes on immediately and stays steadily lit. No start up sound is heard and the display remains black.</p>
<p><strong>Display</strong></p>
<p>The display I reinstalled is fully functional and there is no faint image on the screen. I have also connected a second fully functional display (see photo below) from another MacBook and still nothing comes up. This may rule out a bad display or inverter cable.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/XphLC2eDmbGYN3I2.standard" width="282" height="188" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/XphLC2eDmbGYN3I2.huge&quot;, '', 'width=1600,height=1071')" /></div>
<p><strong>Resetting PMU/SMC</strong></p>
<p>When resetting PMU/SMC, the sleep light would flicker, but no tone was heard after any reconfiguration.</p>
<p><strong>Resetting PRAM</strong></p>
<p>I reset the PRAM, but nothing happened.</p>
<p><strong>Reseat RAM</strong></p>
<p>Initially one RAM card seemed improperly seated, but after removing both RAM cards, switching up the configuration, using different cards, and reinstalling the cards properly, nothing happened.</p>
<p><strong>Reseat Internal Connections</strong></p>
<p>I opened the MacBook again, disconnected all internal cables and reconnected them all, making sure they were properly and securely seated.</p>
<p><strong>Disconnecting/Replacing Optical Drive Cable</strong></p>
<p>I replaced the optical drive cable with another. This initially improved the optical drive's cycling issue upon start up and it operated and sounded normally. After trying to start up with the hard drive disconnected, it went back to cycling. This optical drive is known to be fully functional.</p>
<p><strong>Disconnecting Hard Drive</strong></p>
<p>I disconnected the hard drive cable and attempted to start up the MacBook, but the sleep light did not illuminate and the optical drive started cycling again.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section__Update_11_18_Num_10" class="header"><strong>Update 11/18/10</strong></h3></div>
<p>I got an email back from the Beta Macs company and a phone call from the rep I was emailing with about the logic board yesterday. They said they tested the board in a different machine and that it worked fine for them. I don't know if something they're doing is different from what I did, but the rep called me to tell me that my issues may be from improperly installing the temp sensors and not using thermal paste during reassembly. I'm certain I did both properly with the aid of iFixIt guides. What do you guys think, could it, in fact, be something on my end? I mean, I've tried all the things you suggested to get it working. Beta Macs has fully refunded me the cost of the logic board and the shipping. I've been thinking about ordering the only 1.83GHz 4-wall logic board that iFixIt has in stock, despite it being $100 more than the previous board that I purchased. I feel like there is a higher degree of functional certainty from iFixIt. What would you guys suggest? Once again, thanks so much for your help! You guys have been incredible.</p>
<p>⟐ Answered december 30, 2013 at 21:07 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/35353/MacBook+Core+Duo+not+working+properly+after+internals+were+replaced</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/35353</guid>
<pubDate>Mon, 30 Dec 2013 21:07:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Why is my screen flickering and backlight completely shutting off?]]></title>
<description><![CDATA[<p>This happens periodically, I'm sure it has something to do with the display cables.</p>
<p>Does anyone have an idea of how long or where I could find the cables to replace and which ones will actually fix this?</p>
<p>I've tried doing a display update, which fixed it for about a day.</p>
<p>It doesn't happen all the time, but when it does it is very annoying.</p>
<p>⟐ Answered november 06, 2009 at 18:31 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/9/Why+is+my+screen+flickering+and+backlight+completely+shutting+off</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/9</guid>
<pubDate>Fri, 06 Nov 2009 18:31:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Why was my bluetooth card not recognized?]]></title>
<description><![CDATA[<p>I turned on my MacBook and my Bluetooth was not recognized by the OS. I had to shutdown and restart until it was finally recognized. Could this be a hardware malfunction waiting to happen?</p>
<p>⟐ Answered november 17, 2009 at 19:52 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/2/Why+was+my+bluetooth+card+not+recognized</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/2</guid>
<pubDate>Tue, 17 Nov 2009 19:52:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: MacBook only boots fully occasionally, otherwise black screen]]></title>
<description><![CDATA[<p>Hi!  I've got a MacBook which boots and works fine about 1 in 30 times I try to power it on, and the other 29 it makes bootup noises (but no chime), the optical drive revs up, the power light stays on, but nothing else happens.  When it works occasionally, it works 100%, and stays on pretty much till I power off.  The original owner was told by Apple that it's a GPU problem.  I've tried different memory, replacing the DC-in, PMU and PRAM resets, and nothing seems to make a difference or improve the 1/30 ratio.  I don't suspect the screen, because, again, when it works, it works.  I'm just curious if anyone has any thoughts before I give up and assume it's a bad board.</p>
<p>If you want to see the machine, below is the video I'm using to sell it on EBay.  I've been selling lots of MacBooks for parts lately, and would much prefer to sell this as a working machine!  :-)</p>
<p><a href="http://www.youtube.com/watch?v=vTiwLudfFPY" title="http://www.youtube.com/watch?v=vTiwLudfFPY">http://www.youtube.com/watch?v=vTiwLudfF...</a></p>
<p>⟐ Answered juni 24, 2012 at 14:13 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/883/MacBook+only+boots+fully+occasionally,+otherwise+black+screen</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/883</guid>
<pubDate>Sun, 24 Jun 2012 14:13:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Is it possible to replace MacBook logic board with a later version?]]></title>
<description><![CDATA[<p>My macbook has developed a problem charging, to the extent that it will only run when connected to the mains, and does not charge the battery at all.</p>
<p>This problem developed slowly over time.</p>
<p>I have had the problem diagnosed professionally and tried replacement of battery, magsafe etc etc but these are not the problem.</p>
<p>After carrying out tests, the technician determined that the problem was with a chip on the logic board that controls what the computer does with power; i.e. directing it to the battery etc.</p>
<p>He said that the only way to fix this was to replace the logic board, but that the macbook would continue to work fine connected to mains, which has proved to be true for a number of months.</p>
<p>I am reluctant to spend so much money on repairing a macbook that is now quite old and may need replacement soon anyway. At the same time the macbook is absolutely fine for my uses and I do not need an upgrade yet and as such am reluctant to spend the money until I really need an upgrade.</p>
<p>So, is there a cheaper way to fix this? And if I do replace the logic board can i at least replace it with a later model and get more value for money / a few more years out of my macbook before upgrading?</p>
<p>Thanks!</p>
<p>Colm</p>
<p>If I</p>
<p>2.0GHz (Intel core duo)</p>
<p>⟐ Answered december 30, 2020 at 7:44 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/64506/Is+it+possible+to+replace+MacBook+logic+board+with+a+later+version</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/64506</guid>
<pubDate>Wed, 30 Dec 2020 07:44:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Lines showing on LCD]]></title>
<description><![CDATA[<p>Hi everybody,I am attaching some pictures of the lines on my sons Macbook,</p>
<p>my question is is this a damaged LCD,LCD driver or something else ..?</p>
<p>I like to be sure before I order new LCD</p>
<p>thank you for your time (big help) !</p>
<p>peter</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ZXHJbgeDfA6GGPqW.standard" width="260" height="225" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ZXHJbgeDfA6GGPqW.full&quot;, '', 'width=1009,height=876')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/3QZAjHwHX52bspVX.standard" width="282" height="211" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/3QZAjHwHX52bspVX.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/xqqYeC6cbJSkQFIJ.standard" width="282" height="211" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/xqqYeC6cbJSkQFIJ.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Commented mei 09, 2012 at 11:53 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/6072/Lines+showing+on+LCD</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/6072</guid>
<pubDate>Wed, 09 May 2012 11:53:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Wont boot past grey screen with no logo, chimes over and over]]></title>
<description><![CDATA[<p>My customers 13&quot; MacBook White will not boot up at all. Only a Grey screen, you get the first chime then it just keeps chiming over and over again but the rest are not as loud. I have removed the hard drive no difference. I have removed the memory and that's the only time it wont boot to a screen like expected. I have also tried one memory stick. The only key stroke that works is apple,option ,p,r but after it reboots it still the same thing.</p>
<p>So I have a Chime, Grey screen with NO LOGO, or POINTER btw. And constant chime at lower level after. I think its the board please tell me whats going on.</p>
<p>Owner states he thinks he got a virus on it, then the baby started hitting buttons. After a reboot machine never came back up. But i think I ruled that out by getting the same effect by removing the hard drive.</p>
<p>BIOS / Firmware problems? I have 18 years pc repair my first attempt at mac.</p>
<p>⟐ Commented juni 30, 2018 at 23:47 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/44318/Wont+boot+past+grey+screen+with+no+logo,+chimes+over+and+over</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/44318</guid>
<pubDate>Sat, 30 Jun 2018 23:47:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: My computer won't boot, i'm getting a folder with ? on it]]></title>
<description><![CDATA[<p>My computer won't boot, I'm getting a folder with ? on it. The bottom of the computer seems very hot.</p>
<p>⟐ Answered december 03, 2012 at 0:55 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/2859/My+computer+won&#039;t+boot,+i&#039;m+getting+a+folder+with++on+it</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/2859</guid>
<pubDate>Mon, 03 Dec 2012 00:55:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: LCD flickers when computer not actively in use]]></title>
<description><![CDATA[<p>I have a MacBook Core Duo machine with an LCD that flickers. Normally I'd immediately suspect the inverter, but the behavior on this machine is different from what I've seen before. The flickering usually starts after the computer has been left alone for a few minutes, and then stops if the cursor is moved. Is it still the inverter, or is this caused by something else?</p>
<p>⟐ Answered februari 09, 2010 at 20:44 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/695/LCD+flickers+when+computer+not+actively+in+use</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/695</guid>
<pubDate>Tue, 09 Feb 2010 20:44:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Replacing the inverter board charges]]></title>
<description><![CDATA[<p>Model A1181 2.0 GHz  EMC 2092</p>
<p>I got one in that I need to replace the inverter board on.  The part with shipping will run about $55.00.  I looked at the 45 step teardown just to get to it and that it's listed as a very difficult repair.  I saw online that this could be done for $99.00 at one of the repair services.  My question is:  do they know a better, faster way to replace this part that what the iFixit procedure is?  Do any of you know a faster method?</p>
<p>⟐ Answer deleted april 18, 2013 at 15:59 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/13142/Replacing+the+inverter+board+charges</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/13142</guid>
<pubDate>Thu, 18 Apr 2013 15:59:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Bought the A1181 screw set, any way to measure screws?]]></title>
<description><![CDATA[<p>Re: A1181 LCD replacement Guide</p>
<p>All the screws arrived in a little bag OK, but all mixed up.</p>
<p>Following the reassembly instructions I've tried to measure each screw (REALLY tedious). Especially for 2.2 type sizes (with tenths of a mm). Shank widths; thread depths; cap widths.</p>
<p>I've been using a printer's loupe and a transparent metric ruler.  Also I feel my accuracy is in doubt. I don't want to goof up any threads or round out any Phillips' caps. Is there any method for speeding up tiny screw measurements? A Metal or paper guide?</p>
<p>Thank you,</p>
<p>crocdog</p>
<p>⟐ Commented augustus 06, 2019 at 15:16 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/97409/Bought+the+A1181+screw+set,+any+way+to+measure+screws</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/97409</guid>
<pubDate>Tue, 06 Aug 2019 15:16:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: What kind and how much can I upgrade the RAM to?]]></title>
<description><![CDATA[<p>hello . I bought a MacBook 13.3 core duo black. There is 512 MB of ram only and I would like to upgrade it to 2 or 4 GB.</p>
<p>Can you, please, tell me, do I have to buy some special RAM for Apple or any other is suitable too?</p>
<p>thank you</p>
<p>⟐ Answer accepted maart 19, 2010 at 6:52 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/11108/What+kind+and+how+much+can+I+upgrade+the+RAM+to</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/11108</guid>
<pubDate>Fri, 19 Mar 2010 06:52:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Fan comes on when viewing web video or flash]]></title>
<description><![CDATA[<p>When viewing video online, say YouTube or playing Mafia Wars on Facebook, the fan will come on and rev up very high. Stop and the fan will eventually turn off.</p>
<p>This isn't a recent thing, has been happening forever. Replaced the battery not so long ago and that didn't make a difference. The only mod make to this laptop was upgrading the wireless card to a N card.</p>
<p>2GB Ram</p>
<p>2ghz Intel Core Duo</p>
<p>10.6.2</p>
<p>⟐ Answer accepted augustus 23, 2017 at 19:05 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/11926/Fan+comes+on+when+viewing+web+video+or+flash</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/11926</guid>
<pubDate>Wed, 23 Aug 2017 19:05:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: No backlight, tried inverter, what now?]]></title>
<description><![CDATA[<p>hey guys,</p>
<p>I've tried to fix my problem on my own by following the guide instructions of ifixit. I am having exactly the problem which is described in the Macbook troubleshooting article (The screen is very dark, but everything else seems to be running. If you get in close with a flashlight, you can usually see the image faintly.)</p>
<p>So I bought a new inverter but this did not solve my problem. In my case the backlight is available for 10 - 30 seconds and after that the screen is black and I am only able to get the backlight back for 1 second.</p>
<p>I want to know if connecting my Macbook with an external display via vga and getting an image on the new display...</p>
<p>what would that mean? A working logic board and thus a faulty LCD?</p>
<p>My Macbook is just 3 years old and it would be a disaster for me, when having a faulty logic board. Unfortunately I have not bought an ACPP.</p>
<p>I hope you guys can give me some advice!</p>
<div class="clearer"></div><div class="headerContainer"><h2 id="Section_Update" class="header">Update</h2></div>
<p>Thank you for your help!</p>
<p>I have ordered a minidvi to vga connector and I will check if I am getting a good picture on the external monitor.</p>
<p>Changing the inverter cable was actually not an option for me because I first went to an Apple Service Provider and he told me that the cable couldn't be the problem. Due to the fact that the backlight is gone without moving the display.</p>
<p>But now I will try a new inverter cable!</p>
<p>Maybe it's worth to tell the whole story how the backlight problem started:</p>
<p>My Macbook had only 1 GB of memory and I bought new 2x2 GB of memory. But one of those new memory was faulty. I checked it with rember. Afterwards I upgraded to Snow Leopard and while installing the new OS the backlight was gone. But it was possible to get the backlight back by closing and folding up the display. I decided to switch back to the old memory and downgraded to Leopard but this did not solve my problem.</p>
<p>Yesterday I observed that when using the brightness keys( F1 &amp; F2) I can create for one second backlight. I have to switch down the brightness to zero and then by pressing F2 I can get the backlight back. I repeated this key combination in order to maintain the backlight but then I get a flickering backlight, which only lasts for 3 - 4 seconds before getting a screen with no backlight.</p>
<p>I will post here again when I tried the external monitor/ inverter cable!</p>
<div class="clearer"></div><div class="headerContainer"><h2 id="Section_Update_1" class="header">Update</h2></div>
<p>So the VGA connector arrived and I am getting a good picture on the external monitor!</p>
<p>Today I observed that the backlight of my Macbook was able to last for more than 30 minutes! But afterwards same problem again.</p>
<div class="clearer"></div><div class="headerContainer"><h2 id="Section_LAST_Update" class="header">LAST Update</h2></div>
<p>NO LUCK with the new inverter cable :(</p>
<p>First it seemed to be fixed, since the backlight was available during moving the display which was not possible before. But the backlight was gone after a couple of minutes and did not come back. I also changed the inverter board again but no effect... the inverter board which I ordered for replacing my old inverter was even &quot;worse&quot;. Because my old inverter was able to produce backlight for a couple of minutes and the new inverter only few seconds...</p>
<p>⟐ Commented augustus 20, 2017 at 16:26 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/69120/No+backlight,+tried+inverter,+what+now</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/69120</guid>
<pubDate>Sun, 20 Aug 2017 16:26:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: water damage repair?]]></title>
<description><![CDATA[<p>water entered from underneath. by the battery. i was wondering if there is any way this could be fixed? when i put it to charge it shows that its charging but the computer itself wont turn on. the screen is not on.</p>
<p>⟐ Answer accepted november 13, 2013 at 4:36 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/4816/water+damage+repair</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/4816</guid>
<pubDate>Wed, 13 Nov 2013 04:36:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Core Duo: Can't install OS on new HD]]></title>
<description><![CDATA[<p>I installed a new hard drive in my MacBook, but cannot get Snow Leopard to install.  I did the replacement according to ifixit.com and then partitioned it and ran erase.  When I start up with the disk, everything seems to be going fine - the new HD shows as destination for install and the screen says it's installing the OS.  It says there are 30 minutes left and then an error screen comes up that says there's a software problem and to retry.  I've tried about ten times, same result.  Do you have any idea what's going on and how I can fix it so I can install the OS?  I've even tried installing Tiger from an old disk, but nothing at all happened - just a blank screen.  Please help!</p>
<p>⟐ Answer accepted december 08, 2013 at 4:37 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/63820/Can&#039;t+install+OS+on+new+HD</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/63820</guid>
<pubDate>Sun, 08 Dec 2013 04:37:03 -0700</pubDate>
</item>
</channel>
</rss>
