<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;FixHub Portable Soldering Station&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/FixHub_Portable_Soldering_Station?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;FixHub Portable Soldering Station&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 06 Aug 2026 05:48:16 -0700</pubDate>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Is firmware 1.4.0 boot looping with error B02 & low 0% battery known?]]></title>
<description><![CDATA[<p>Has anyone else experienced the following?  Is this firmware issue known to those at iFixit working on FixHub?</p>
<p>I bought the FixHub soldering station kit sometime in February-March 2025, when the FixHub was still marked for pre-order (I think?), but was already on the shelves of Micro Center.  I had only tried to turn it on for the first time after purchase yesterday (which in hindsight was an extreme misjudgement for quality checks of purchased tools that are relatively valuable).  So, naturally I figured the battery probably drained out during that time.</p>
<p>I saw mentions of updating the FixHub's firmware via web searching, but I wasn't able to figure out how to do so until today.  I was able to use the FixHub's web console <a href="https://www.ifixit.com/fixhub/console" target="_blank">page</a> to update the FixHub to the latest version of 1.4.0.  So, at least the FixHub wasn't dead on arrival.</p>
<p>However, 1.4.0 firmware version ends up in a very bad edge/corner case when the device is drained to 0%, has its firmware immediately updated to 1.4.0, and then attempts to charge its completely drained internal battery.</p>
<p>Generally FixHub will attempt to charge and the charging animation will come up, but eventually within 10-15 seconds encounter battery error B02/battery disconnected (though only once I saw it experience battery error B04/battery charging stopped for protection in the error logs part of the settings).  (The FixHub error codes can be looked up <a href="/Wiki/FixHub_Error_List" target="_blank">here</a>.)  The FixHub will then turn itself off, and the empty battery icon will show when FixHub is turned off.  If one attempts to turn of FixHub in this state, then the normal on menu will come up, but the battery icon will flash between completely empty (with just the battery outline) and the slightest line charge to show the 0% battery state.  Due to this state, one can only get FixHub to navigate through the settings menu, but won't be able to heat up to solder.  Not even using a non-PD cable of USB-A and USB-C could get the FixHub to begin charging past 0%.</p>
<p>I was able to resolve this issue by downgrading the firmware (or conducting a firmware downgrade attack, if the FixHub were to be used in a more stringent infosec scenario; but also not really because there was no firmware rollback protection in the first place) to the second latest firmware version 1.32, as I found the FixHub web console was still always able to work with the web serial interface.  (Coincidentally, this reminds me of the web installer for Google Pixel/GrapheneOS, as these also seem to only work with Chromium-based browsers.)  The process may have failed once at most, though I was able to simply refresh the FixHub web console page to start the process over again very quickly.  Once I successfully flashed firmware version 1.3.2, then FixHub was able to charge with a &quot;typical&quot; GaN charger from 0% with no boot looping.</p>
<p>Although this is likely a rare edge case &quot;in the field&quot;, if this issue can be reproduced, then I would recommend that this boot looping issue should be fixed in the next FixHub firmware release.</p>
<p><em>Update</em>: I was able to upgrade the firmware from version 1.3.2 to 1.4.0 after the FixHub was fully charged.  (I made sure to reset the battery health via the web console.)  Before I upgraded the firmware and probably when the battery became fully charged (I wasn't home while it charged), the FixHub experienced a total of at least 4 consecutive B16 battery errors/battery warm (not hot).  (The FixHub can only save a max of the latest 4 errors in the error log.)  After about 2-3 failed attempts of upgrading the firmware from 1.3.2 to 1.4.0 (including when there was a false success result and the firmware stayed at 1.3.2), the FixHub was able to update to firmware 1.4.0.  I will test to make sure the soldering functions work on the FixHub, to make sure the FixHub functions properly.  If I don't make any further edits, then assume that the FixHub is working fine.</p>
<p><em>Final update</em>: This issue seems to have been addressed in firmware version 1.4.2.  According to the release notes for this version on August 8, 2025, the changelog on the console page states:</p>
<blockquote class="featured"><ul><li>Fixed bootlooping errors that occurred when charging a dead battery</li><li>Improved accuracy of charge timer warnings</li><li>Minimized interruptions and clarified language regarding battery temperature errors</li></ul></blockquote>
<p>⟐ Commented april 20, 2026 at 16:51 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/906765/Is+firmware+1.4.0+boot+looping+with+error+B02+&amp;+low+0%25+battery+known</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/906765</guid>
<pubDate>Mon, 20 Apr 2026 16:51:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: FixHub won’t charge out of the box.]]></title>
<description><![CDATA[<p>Just opened up my set I got as a gift. The iron works great but the hub won’t charge. I put it on a charger that reports draw and it just keeps cycling on an off at 0.1w. I also tried to connect it to my computer to see if the online tool worked but no luck. I have also tried 3 other usb c cables to no luck. I also took the unit apart and disconnected and reconnected the battery.</p>
<p>Guessing I may have a lemon but wanted to check here first…</p>
<p>⟐ Answer edited juli 29, 2025 at 1:10 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/887309/FixHub+won%E2%80%99t+charge+out+of+the+box.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/887309</guid>
<pubDate>Tue, 29 Jul 2025 01:10:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: What does "Tool Error Actuator Fault" mean?]]></title>
<description><![CDATA[<p>This is the first day I have used the soldering station. It mostly worked well, but one time I got: &quot;Tool Error: Actuator Fault&quot;</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/OUmHS22mB2I4T5ya.standard" width="282" height="211" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/OUmHS22mB2I4T5ya.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>What does this mean, and how can I prevent it from happening in the future?</p>
<p>The battery was fully charged when I started, and was about 75% when I finished for the day.</p>
<p>Also, probably related, several times when I turned the power station on with the soldering iron connected, I got this screen:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/orCuOCgZEwRtrUR5.standard" width="282" height="211" class="hasMenu hasLarge" alt="Afbeelding" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/orCuOCgZEwRtrUR5.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>What can I do about this? It went away when I power cycled.</p>
<p>⟐ Commented juli 23, 2025 at 18:29 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/877367/What+does+%22Tool+Error+Actuator+Fault%22+mean</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/877367</guid>
<pubDate>Wed, 23 Jul 2025 18:29:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: My FixHub is dead, won't turn on or charge]]></title>
<description><![CDATA[<p>Subject says it all.  It's dead. It won't charge. It won't do anything. It's bricked.  Any suggestions??</p>
<p>⟐ Commented juli 20, 2026 at 9:18 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/900904/My+FixHub+is+dead,+won&#039;t+turn+on+or+charge</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/900904</guid>
<pubDate>Mon, 20 Jul 2026 09:18:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Misaligned Firmware Error in Fix It Hub Console (v1.4.0)]]></title>
<description><![CDATA[<p>Firmware version 1.4.0 is consistently triggering a &quot;misaligned firmware&quot; error in the Fix It Hub Console.</p>
<p>I’ve confirmed that both the Smart Station and the Iron are running firmware version 1.4.0. However, when I downgrade both devices to version 1.3.2, the error disappears.</p>
<p>I believe this may be a false error. When I check the firmware directly from the Smart Station’s menu, it correctly reports that both the Smart Station and the Iron are on version 1.4.0.</p>
<p>However, when I click on the error message in the Fix It Hub Console, it shows the Iron firmware as <strong>blank</strong>, while the Hub firmware still shows 1.4.0.</p>
<p>I’ve also tested this on a second computer to rule out a browser issue, and the behavior is the same.</p>
<p>Any thoughts on what might be causing this?</p>
<p>⟐ Commented april 20, 2026 at 16:53 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/906798/Misaligned+Firmware+Error+in+Fix+It+Hub+Console+(v1.4.0)</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/906798</guid>
<pubDate>Mon, 20 Apr 2026 16:53:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Selling the station seperate]]></title>
<description><![CDATA[<p>Hi I was just wondering if you know if ifixit will be selling the stations seperate or if you have to get it in the kit</p>
<p>⟐ Commented november 28, 2025 at 23:11 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/891846/Selling+the+station+seperate</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/891846</guid>
<pubDate>Fri, 28 Nov 2025 23:11:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Ifixit Soldering Station Problems keeps disconnecting]]></title>
<description><![CDATA[<p>So i bought a Ifixit Hub and within in a week both tips failed and i was getting battery errors showing on the hub, so contacted ifixit and they sent me out a replacement hub and iron. But sadly this one did not work either, after playing around for a few hours i found that i had to keep unplugging the usb c until the iron registered with the hub then i would have to unplug the tip a few times to get it top actually work.</p>
<p>I was then asked to update the firmware but then found out the updater was switched off due to a current firmware issue, but they have fixed that now and i was able to update the firmware. The Soldering iron does seem a little better but i still have to unplug it  a few times to actaully get it to work. When i switch the hub on the iron shows as connected and the temp shows but as soon as i switch the iron on it disconnects and i have to unplug it a few times to get it to work again.</p>
<p>Has anyone else had this issue and found the way to fix this?</p>
<p>I love the design etc but i need it to just work!</p>
<p>Sadly contacting for support is very slow and can take a few days just to get a reply to say update firmware, or have you tried removing the tip etc, basically the first things you would check and not need to be told to check! They really need a dedicated support email</p>
<p>⟐ Commented juli 12, 2026 at 4:50 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/886472/Ifixit+Soldering+Station+Problems+keeps+disconnecting</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/886472</guid>
<pubDate>Sun, 12 Jul 2026 04:50:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Soldering tip not recognized when powering on the iron]]></title>
<description><![CDATA[<p>Dear all,<br /><br />my hub is running on firmware 1.06 it starts up normally and recognizes the tip in the iron:<br /><br />When I switch the iron itself on, the hubs suddenly says that there is no tip connected.<br /><br />Switching the hub off and on again leaving the iron in the same port shows the same error.<br /><br />When I plug the iron to the other port and cycle power of the hub, it works until the next restart of the hub.<br /><br />I already tried another tip but that didn´s solve the problem:<br /><br />Do you have any idea what to do?<br /><br />Best regards<br /><br />  Andreas</p>
<p>⟐ Answered april 20, 2026 at 13:53 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/884961/Soldering+tip+not+recognized+when+powering+on+the+iron</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/884961</guid>
<pubDate>Mon, 20 Apr 2026 13:53:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: How much charge can the battery hold and can it be used as a powerbank]]></title>
<description><![CDATA[<p>Am wondering how much can the battery hold in mAh and if i can use it to for example charge my phone</p>
<p>⟐ Answered december 14, 2024 at 21:22 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/869324/How+much+charge+can+the+battery+hold+and+can+it+be+used+as+a+powerbank</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/869324</guid>
<pubDate>Sat, 14 Dec 2024 21:22:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: My FixHub does not turn on reliably]]></title>
<description><![CDATA[<p>I have had my FixHub for a couple of weeks, trying to get through its issues.  When it works, I am thrilled to have it. But when it doesn't, it's very frustrating.  My FixHub was basically hopeless at first.  Very erratic and random repeatability of many problems.  Then I updated from FW 1.0.3 to 1.1.2.  Seems better and most of the random issues are gone.</p>
<p>But one remains.  The unit does not turn on reliably.  Sometimes it turns on as it should with a 3 sec push of the blue button. Most of the time it does not.</p>
<ul><li>Sometimes the introductory splash screen will start, then stop and go away.</li><li>Sometimes repeating the attempt a few more times, it may eventually come on.</li><li>Sometimes pushing the blue and silver buttons for ten seconds to reset, then it will power up, but not always.</li><li>Sometimes nothing I do will bring it alive, so I just walk away, only to have it work the next day.</li></ul>
<p>This behavior seems to be independent of room temperature (55-70F) and battery status (40-100%).</p>
<p>The FixHub is a very cool concept and I want to love it, but I can't until it works reliably.  I was hoping to be able to use it for remote repairs, but the last thing I need is to be on a mountain top in the field and not have the FixHub perform.</p>
<p>I have tried all the advice I can find on your website, but no joy yet.  Help please!  Thanks!</p>
<p>⟐ Commented maart 04, 2025 at 4:02 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/888480/My+FixHub+does+not+turn+on+reliably</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/888480</guid>
<pubDate>Tue, 04 Mar 2025 04:02:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Some Soldering Station Suggestions for the Team]]></title>
<description><![CDATA[<p>This is directed to the iFixit team:<br /><br />Hey iFixit team!<br />I love the work you do and at this point have a severe case of brand loyalty. Unfortunately, I have a few glaring issues with the product I hope can be fixed in another iteration:<br />- Usage of Torx screws instead of Philips on the back of the battery pack<br />- Non-replaceable usb-c ports on both the battery pack and iron<br />- Closed source firmware<br />- Cannot use other soldering tips (perhaps you could create an adapter for other types?)<br />- Needing another tool to remove the battery connector<br />- Soldering iron cap has no insulation or heat changing paint<br />- No discharge balancer on the battery pack<br />- Removing the kickstand hurts the surrounding rubber and can scratch the battery pack shell easily<br />- Selector knob is soldered on instead of using a ribbon cable or press on connector<br />- Power button is soldered on instead of another connector style<br />- No plastic shell around battery cells to prevent puncture <br /><br />Things I'd like to see but aren't major issues:<br />- Actnano waterproof coatings<br /><br />Overall, I'm very proud of iFixit, but also hoping that these issues can be addressed. I've seen many of these concerns posted by other individuals elsewhere and this is a compilation of every concern I have found. My four biggest issues are the usage of Torx screws, the non-replaceable usb-c ports, the closed source software, and the single board design of the iron itself. The more modular and replaceable pieces are, the better.<br /><br />Are any of these things we can look forward to in the future?<br /><br />As a side note, I’m also wondering: is there’s any chance of another revision to the electric precision screwdriver with more torque and a rechargeable battery?</p>
<p>⟐ Answer accepted februari 13, 2025 at 14:18 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/887688/Some+Soldering+Station+Suggestions+for+the+Team</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/887688</guid>
<pubDate>Thu, 13 Feb 2025 14:18:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: FixHub stuck in "Firmware update needed" loop after successful update]]></title>
<description><![CDATA[<p>I have a FixHub Portable Power Station that is stuck in a firmware update loop. The screen displays &quot;Station Error: Firmware update needed.&quot; I have successfully run the update through the FixHub Web Console using a data-capable cable connected to the rear port. The console reports &quot;Update Successful,&quot; but as soon as I unplug the device and turn it back on, it displays the same &quot;Firmware update needed&quot; error.</p>
<p>I have already tried:</p>
<p>1. Performing a force shutdown (holding the Action Button for 10 seconds).</p>
<p>2. Attempting to update multiple times via the Web Console.</p>
<p>The error persists every time I power the device back on. Does anyone have any ideas?</p>
<p>⟐ Answered mei 02, 2026 at 7:28 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/950369/FixHub+stuck+in+%22Firmware+update+needed%22+loop+after+successful+update</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/950369</guid>
<pubDate>Sat, 02 May 2026 07:28:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Improvements suggestion (Web interface + Second soldering)]]></title>
<description><![CDATA[<p>Hi all!</p>
<p>This is not exactly a question, but I haven't found better place :(</p>
<p>While this suggestions are meant mostly for iFixit team, but because I couldn't find any e-mail to write to iFixit, I'm writing them here on the forum. And on the second thought, maybe you (the other users) have similar feelings like me and you can - so to speak - &quot;vote&quot; on those suggestions :)</p>
<p><strong>Before I begin, a little story</strong>.</p>
<p><em>If you're from iFixit team, please read. If you here just for suggestions, just jump straight to &quot;Suggestions&quot; section :)</em></p>
<p>I'm not any pro user, not pro repairer. I just needed good soldering iron for very occasional fixes. Or maybe for future when I finally some day start learning with electronics... anyway, here in Poland most of soldering irons are available as iron connected directly to mains in the wall. Sometimes maybe with additional temp control and nothing more. And it takes few minutes to heat up...</p>
<p>So I asked friend who did some electronics and he immiedately proposed me iFixit. Well... it wasn't really proposal... it was more like &quot;I've got iFixit, and you must get it, there's nothing else so good&quot;. (Friend moved to US, I'm still in Poland)</p>
<p>I looked into website, ordered with kinda pain in the wallet and tear in my eye due to price. Yeah, I didn't want to order small pieces, so I decided to order probably most expensive set &quot;FixHub | Power Series Soldering Toolkit&quot; with almost everything. Along some tools like Magnetic Pickup Tool and FixMat (that's a cool one!).</p>
<p>I've had slight problems at first startup (read 1st suggestion in which I explained), but after 2 uses... I must say... I was amazed and this is exactly textbook example of difference between &quot;price&quot; vs. &quot;value&quot;. Because this thing is %#*@ cheap by what it gives!</p>
<ul><li>Battery pack so I can use it on-the-go? Hell yeah! I do occasional side gigs (literal gigs lol) being technicial/live sound mixing guy, and I've seen multiple times that other techs fixed something right before concert because something broke. Other tools I looked in the shops? Need standard wall power... and while there's a lot of power at concerts, it's always very inconvinient to iron with cable hanging on the back of the rack in half-darkness or whatever, so it's great to have battery!</li><li>Heating speed - ON MY GOD IT'S SO FAST!!! It takes me 10x longer to take this Hub from my closet, open pouch, take the Hub off, take the USB-C table off it, take the iron out of it, connect together and start than actually wait for heating... The tip of iron gets into 270C in just few seconds! There's your value, RIGHT THERE! I love it. No need to connect ironing tool into socket, and go make a tea and eat half a dinner because now you have to wait 5 minut with traiditional ironing tool to heat... not to mention, how unprecise such heating it, while in iFixit I can specify temperature very precisely.</li><li>Oh, should I mention the solder cap so I don't burn myself by accident when I finish using it?</li></ul>
<p>I also ordered this to be able to push insets into my 3D prints (so I need to heat inset and just push), and I was worried that minimum possible temperature of 200C is too high for this, as PLA starts melting at about 65-70C. Turned out... I didn't need to worry, because I would need constant heat of 65C for weeks/months in order to PLA start melting. I started with 200C and I wasn't able to melt that plastic, so... yeah, no need to worry if you want to use this with 3D printing, as you still need to set it to 250-270C like your 3D Printer does in order to melt plastic fast :D</p>
<p>After those experiences - even including initial problems - it's still the best money I've ever spent. Even for my very occasional use (just few times a year at most!).</p>
<p><strong>Finally the Suggestions</strong>:</p>
<p><strong>1. Web interface</strong></p>
<p>At first I've had problems starting device, read few articles, turns out some devices were sent with some weird problematic firmware and I just had to do update. Sounds easy right? Especially that I found out, that I can simply connect device into computer, and there's nice web site that can access RS232 devices - and this soldering hub to be specific.</p>
<p>Well... there was issue I didn't understand at I don't think I read somewhere specifically - The Hub has separate web UI than soldering iron itself.</p>
<p>I mean - it's obvious that they have since they are different devices, but it wasn't exactly clear.</p>
<p>What I mean is: on Hub web UI I can upgrade Hub's firmware. But I need to connect iron separately to computer in order to upgrade Soldering Iron firmware. Then I also discovered that I can control Soldering Iron from Chrome (not exactly useful feature to me, due to where my docking station is placed on the desk, but hey, cool feature and might be very useful in some occasions!).</p>
<p>The problem I had is that on Hub's web UI, I was seeing that Iron was connected to one of the USB-C ports, so I was somehow trying to find a way to set parameters of Soldering Iron and upgrade firmware (essentially, access UI of the Iron itself since this is was I was seeing in Google Search)! But it turned out to be not possible and I just had to connect Iron separately.</p>
<p>So the suggestion is:</p>
<ul><li>Can we have possibility of upgrading Iron's firmware along with controlling specific Irons through Hub's web interface? That would make updating firmware and general operation far easier to understand for first-time users :)</li><li>Also, on <a href="https://www.ifixit.com/fixhub/console">https://www.ifixit.com/fixhub/console</a> please explain why Firefox is not compatible. Given how false such info are on many websites, I tend to simply switch User Agent to access website on Firefox. But it turned out, you need Serial access through browser which is really technical limitation this time. Please just include &quot;Hey, you're browser doesn't support Serial access so you need to use another one&quot; :)</li></ul>
<p><strong>2. Offline web UI</strong></p>
<p>Given what I wrote about live concert situation, usually there's no internet at the place, and even if we could use LTE/5G, it's very inconvinient as we already have our devices usually connected to mixers or other audio control equipment, so switching networks (thus disconnecting Wi-Fi) is not really convinient as there's quite high level of multi-tasking during stage setup.</p>
<p>That might be already done as it's possible to configure web page to save itself into browser in a way to work offline, I haven't tested to be honest.</p>
<p><strong>3. Official Longer USB-C cable</strong></p>
<p>The Hub supports up to 2 soldering irons at the same time. Personally I don't find need for this, but it might be very useful for some people. The problem I discovered is that the USB-C cable that somes with Hub+Iron bundle is ok for personal use, but I feel it might be slightly too short for dual-people use. I might be wrong because I was not in two-people situation - so let the others decide if this suggestion is even valid in the first place.</p>
<p>It's not really problem to buy longer high-wattage USB-C cable. But the official one is <strong>very</strong> flexible which is great for the ironing task, and finding something so flexible is kinda impossible.</p>
<p>Thanks iFixit!</p>
<p>⟐ Answered april 29, 2026 at 18:45 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/937498/Improvements+suggestion+(Web+interface+++Second+soldering)</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/937498</guid>
<pubDate>Wed, 29 Apr 2026 18:45:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: FixHub no longer turns on after 2 days - please help]]></title>
<description><![CDATA[<p>When I first got the unit, it would not fully power off ever. If you long pressed the button, it would shut off, then immediately turn back on. I let it fully die, and now it won't turn on at all, no matter how long I have it plugged in, to different power sources, different cables, and with higher output charges. I'm looking at the motherboard and there is a red LED indicator that is on near a &quot;D6&quot; on the board and another comes on near a &quot;D4&quot; on the board.</p>
<p>Please advise - there is something definitely wrong with the portable power station</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_11_15_Num_24" class="header">Update (11/15/24)</h3></div>
<p>When plugging it into the computer, it shows the unit is in DFU mode, and says the firmware is on an unofficial build. Trying to restore it to a previous version</p>
<p>⟐ Commented maart 12, 2025 at 19:40 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/877233/FixHub+no+longer+turns+on+after+2+days+-+please+help</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/877233</guid>
<pubDate>Wed, 12 Mar 2025 19:40:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: What is the max temperature?]]></title>
<description><![CDATA[<p>How high does the temperature go? Will this be hot enough to repair game console hdmi ports that require a big heat output? I’m also curious to know if y’all will be selling a portable hot air station as well.</p>
<p>⟐ Commented september 16, 2024 at 12:08 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/869214/What+is+the+max+temperature</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/869214</guid>
<pubDate>Mon, 16 Sep 2024 12:08:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Future heat set insert tip(s)?]]></title>
<description><![CDATA[<p>Have you guys thought about providing a tip to be used with heat set inserts? Preferably one that would allow you to change the tip to match the size of the insert?<br /><br />Example: <a href="https://a.co/d/0hXTSzc0?tag=ifixitam-20" rel="nofollow noopener noreferrer">Heat Set Insert Tip</a></p>]]></description>
<link>https://nl.ifixit.com/Answers/View/942285/Future+heat+set+insert+tip(s)</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/942285</guid>
<pubDate>Wed, 25 Feb 2026 19:17:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Issues with latest Firmware Update]]></title>
<description><![CDATA[<p>Hi all,</p>
<p>I recently updated the Soldering station and Smart soldering iron to 1.4.3, and went about with soldering no issue.</p>
<p>After a little while, i got an error on the screen of the station, asking me to update to the latest firmware.</p>
<p>When i plugged it into a Computer and opened the ifixit console online, it tells me that the update is not complete. When attempting to finish the update, it will install no problem, but then continue to tell me the update still isn't fully installed, and wont let me continue to solder.</p>
<p>Downgrading to a later update, such as 1.3.x, will remove the onscreen error, but wont connect to the soldering iron. Even when downgrading the tip, the error still persists.</p>
<p>Going as far as downgrading both devices to Version 1.x.x, it will still say that the update is incomplete.</p>
<p>After disassembling the device for a visual inspection, there are two LED's flashing on the inside. D4 seems to flash almost constantly, but with D6 flashing when trying to perform any sort of update alongside D4.</p>
<p>Currently stuck as i have soldering jobs to finish but a soldering station that doesn't work.</p>
<p>Any advice or a fix would be great.</p>
<p>Thanks in advance.</p>
<p>Will CTMT</p>
<p>⟐ Commented mei 02, 2026 at 15:14 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/940501/Issues+with+latest+Firmware+Update</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/940501</guid>
<pubDate>Sat, 02 May 2026 15:14:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Battery Charge Time Seems Super Slow]]></title>
<description><![CDATA[<p>Recently been using my new soldering station and needed to charge the battery.  Plugged it into a 2A fast charger (old Samsung phone charger).  Battery was at 15% at 6 PM (Monday), at 7 AM (Tuesday), it is at 60%.  Looks like a full day to charge this battery based on that schedule.  Any recommendation for speeding up the time.  I did try a variety of charging bricks with no significant change in charging speed.</p>
<p>⟐ Answer edited april 15, 2025 at 10:14 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/896115/Battery+Charge+Time+Seems+Super+Slow</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/896115</guid>
<pubDate>Tue, 15 Apr 2025 10:14:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: Fixhub reports no new firmware while still on 1.0.3]]></title>
<description><![CDATA[<p>I received my fixhub today and I am very happy with it. It is my first upgrade from my weller (with resistors to set the temperature). It is very fast on the set temperature and feels comfortable to use.</p>
<p>When connected to my pc it reports firmware version 1.0.3. (both station as soldering pencil) but not a newer version available. I read about many other versions up to 1.0.7 and a almost released 1.0.8.</p>
<p>I tried with edge, chrome and opera, all connected without any issues but no newer firmware versions or the option to upgrade or downgrade.</p>
<p>Not sure what to do to get it updated.</p>
<p>⟐ Answer accepted februari 12, 2025 at 3:11 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/885053/Fixhub+reports+no+new+firmware+while+still+on+1.0.3</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/885053</guid>
<pubDate>Wed, 12 Feb 2025 03:11:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[FixHub Portable Soldering Station: FixHub Portable Soldering Station Battery Health at 82% upon arrival?]]></title>
<description><![CDATA[<p>Upon arrival (2024 October 21) the battery bank included with the FixHub Portable Soldering Station was at 82%. I charged it and used it once (maybe 2 hours), recharged the battery, and the self-reported health is at 82%.  This seems abnormal for minimal use and age while being kept inside.<br /><br />Is this a faultly battery and should it be exchanged it for another one?</p>
<p>⟐ Answer edited januari 09, 2025 at 6:58 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/881526/FixHub+Portable+Soldering+Station+Battery+Health+at+82%25+upon+arrival</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/881526</guid>
<pubDate>Thu, 09 Jan 2025 06:58:22 -0700</pubDate>
</item>
</channel>
</rss>
