<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Craftsman Air Compressor&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Craftsman_Air_Compressor/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Craftsman Air Compressor&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 18 Jul 2026 07:16:40 -0700</pubDate>
<item>
<title><![CDATA[Craftsman Air Compressor 92115215 2012: craftsman model 921 152150 pancake air compressor]]></title>
<description><![CDATA[<p>how do i remove the power switch?</p>
<p>⟐ Commented februari 19, 2026 at 17:48 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/925235/craftsman+model+921+152150+pancake+air+compressor</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/925235</guid>
<pubDate>Thu, 19 Feb 2026 17:48:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 919.155612: What is the capacitor size]]></title>
<description><![CDATA[<p>what is the capacitor size</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/928243/What+is+the+capacitor+size</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/928243</guid>
<pubDate>Thu, 27 Nov 2025 21:18:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 91915309 2016: What tool do I need to take the cover apart]]></title>
<description><![CDATA[<p>My compressor won’t build air. I think it’s leaking where the gauges and the pressure regulator connect to the compressor itself. What tool do I need to take the housing apart?</p>
<p>⟐ Commented november 06, 2025 at 22:03 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/925065/What+tool+do+I+need+to+take+the+cover+apart</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/925065</guid>
<pubDate>Thu, 06 Nov 2025 22:03:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 9191672 2016: Compressor motor restart problem]]></title>
<description><![CDATA[<p>Craftsman 5 HP air compressor, model 919.167200</p>
<p>Compressor runs ok and switches off when set point is reached. Motor trips breaker when attempting a restart at lower pressure point. Evaluated check valve, unloader valve, and pressure switch, and all are functioning properly. Both the run and start caps are fine. Since the motor starts with no tank pressure the centrifugal switch for the caps appears to be working.</p>
<p>Any other possible issues to consider?</p>
<p>⟐ Edited oktober 22, 2025 at 17:51 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/923005/Compressor+motor+restart+problem</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/923005</guid>
<pubDate>Wed, 22 Oct 2025 17:51:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 91916731 2014: Leaking air from pressure regulator]]></title>
<description><![CDATA[<p>Hello i have a leak behind the pressure regulator knob in a small hole looks to be there from factory the only way to stop it is turning the pressure all the way yup is this normal</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/908380/Leaking+air+from+pressure+regulator</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/908380</guid>
<pubDate>Sun, 20 Jul 2025 16:20:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 919.155612: Porque mi compresor no arranca]]></title>
<description><![CDATA[<p>Porqué mi compresor no arranca</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/901936/Porque+mi+compresor+no+arranca</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/901936</guid>
<pubDate>Thu, 29 May 2025 14:02:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 91916731 2014: Motor cover removal sequence]]></title>
<description><![CDATA[<p>How to remove the plastic cover of the motor?</p>
<p>⟐ Answered februari 28, 2025 at 1:40 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/889390/Motor+cover+removal+sequence</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/889390</guid>
<pubDate>Fri, 28 Feb 2025 01:40:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 919152812 2016: Wiring diagram craftsman 60 gal 240 volt single stage upright air comp]]></title>
<description><![CDATA[<p>Show a wiring diagram for craftsman 60 gallon 240 volt single phase upright air compressor</p>
<p>⟐ Commented januari 18, 2025 at 16:41 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/883638/Wiring+diagram+craftsman+60+gal+240+volt+single+stage+upright+air+comp</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/883638</guid>
<pubDate>Sat, 18 Jan 2025 16:41:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 15206 2017: Removing compressor regulator on Evolve air compressor]]></title>
<description><![CDATA[<ol><li>What tool or access method will allow me to remove the pressure regulator assembly?</li></ol>
<p>⟐ Answered oktober 10, 2024 at 17:35 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/872951/Removing+compressor+regulator+on+Evolve+air+compressor</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/872951</guid>
<pubDate>Thu, 10 Oct 2024 17:35:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 9211664 2016: Craftsman air compressor screws]]></title>
<description><![CDATA[<p>I have a Model # 16957 Official Craftsman air compressor that has some weird screw heads. They have a nipple and a slot  Can someone help with identifying these? Sorry the pic isn't very good the screw head is inside the shroud</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/grKpwodxwPRNAmO6.standard" width="207" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/grKpwodxwPRNAmO6.full&quot;, '', 'width=1080,height=1178')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/jXA4NcQxCBFW2Xqn.standard" width="207" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/jXA4NcQxCBFW2Xqn.full&quot;, '', 'width=1080,height=1178')" /></div>
<p>⟐ Answer edited augustus 25, 2024 at 22:23 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/866529/Craftsman+air+compressor+screws</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/866529</guid>
<pubDate>Sun, 25 Aug 2024 22:23:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 91916644 2016: Removing the shroud from a Craftsmam Model 919.166440 air compressor]]></title>
<description><![CDATA[<p>Can anyone tell me what size and what length Torx bit is needed to remove the screws holding the shroud on this model air compressor?</p>
<p>⟐ Commented augustus 23, 2024 at 17:46 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/839142/Removing+the+shroud+from+a+Craftsmam+Model+919.166440+air+compressor</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/839142</guid>
<pubDate>Fri, 23 Aug 2024 17:46:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 921153101 2012: يتسرب الهواء في الجو Air leaks into the atmosphere]]></title>
<description><![CDATA[<p>يتسرب الهواء في الجو</p>
<p>Translate Arabic - English</p>
<p>Air leaks into the atmosphere</p>
<p>⟐ Edited juni 11, 2024 at 20:53 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/854171/%D9%8A%D8%AA%D8%B3%D8%B1%D8%A8+%D8%A7%D9%84%D9%87%D9%88%D8%A7%D8%A1+%D9%81%D9%8A+%D8%A7%D9%84%D8%AC%D9%88+Air+leaks+into+the+atmosphere</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/854171</guid>
<pubDate>Tue, 11 Jun 2024 20:53:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 919152145 2017: Why is it not powering on?]]></title>
<description><![CDATA[<p>Just got the compressor when I turn switch and nothing happens</p>
<p>⟐ Answered december 04, 2022 at 13:31 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/758235/Why+is+it+not+powering+on</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/758235</guid>
<pubDate>Sun, 04 Dec 2022 13:31:54 -0700</pubDate>
</item>
</channel>
</rss>
