<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Carpet Cleaner&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Carpet_Cleaner/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Carpet Cleaner&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 02 Sep 2026 23:04:55 -0700</pubDate>
<item>
<title><![CDATA[McCulloch MC-1275 Heavy Duty Steam Cleaner: Troubleshooting heats but not working]]></title>
<description><![CDATA[<p>When the button is pressed steam is not coming out.  I know that the machine is correctly heating to temperature and setam seeps in order to not over pressurize but not sure how to fix the problem</p>
<p>⟐ Commented augustus 21, 2026 at 22:43 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/390786/Troubleshooting+heats+but+not+working</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/390786</guid>
<pubDate>Fri, 21 Aug 2026 22:43:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bissell ProHeat 2X Cleanshot: I need a Hose Plumbing diagram for Bissell ProHeat 2X CleanShot Model]]></title>
<description><![CDATA[<p>I was given a Model #9500 after a friend tore it down and could not put it back together. I have found the service center guide for the Model 9200 thru 9400 but it is not the exact same as the #9500. The difference is the flow gauge plumbing.</p>
<p>Thanks in advance.</p>
<p>⟐ Commented augustus 02, 2026 at 23:07 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/458847/I+need+a+Hose+Plumbing+diagram+for+Bissell+ProHeat+2X+CleanShot+Model</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/458847</guid>
<pubDate>Sun, 02 Aug 2026 23:07:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Rug Doctor Carpet Extractor Wide Track 95371 2016: Mighty pro rug doctor x3 shut off six minute run]]></title>
<description><![CDATA[<p>Why every six minute shut off</p>
<p>⟐ Commented juli 27, 2026 at 10:43 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/755047/Mighty+pro+rug+doctor+x3+shut+off+six+minute+run</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/755047</guid>
<pubDate>Mon, 27 Jul 2026 10:43:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Carpet Cleaner: Lavex Dual 2-Stage Cold Water Carpet Extractor - water not coming out]]></title>
<description><![CDATA[<p>Hello! I am the Board president of a large condo building that boguht a Lavex Dual 2-Stage Cold Water Carpet Extractor (12 gallon, 100 PSI) about a year ago.</p>
<p>We just finally unpacked it (our old cleaner finally broke down) and set it up. Everything seemed to be in order, but the when I pull the handle to release water, a little bit of water dripped out and then nothing.</p>
<p>I'm worried we may be out of warranty since it's been over a year since purchase, though I'm trying to get in touch with manufacturer. Any ideas on how to troubleshoot this? Or, is there any advice on where I could find someone locally that might be able to look at and diagnose this?</p>
<p>Thank you!</p>
<p>⟐ Answered juli 11, 2026 at 7:41 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/963493/Lavex+Dual+2-Stage+Cold+Water+Carpet+Extractor+-+water+not+coming+out</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/963493</guid>
<pubDate>Sat, 11 Jul 2026 07:41:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Carpet Cleaner: I need a special tool to get my shark vacuum apart]]></title>
<description><![CDATA[<p>The fasteners look like an allen head with a pin in the middle. Looks like you would need an allen wrench with a tiny hole drilled in the middle of it. Any ideas what/where I could get a tool like this?</p>
<p>⟐ Commented juli 09, 2026 at 13:55 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/433204/I+need+a+special+tool+to+get+my+shark+vacuum+apart</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/433204</guid>
<pubDate>Thu, 09 Jul 2026 13:55:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bissell SpotClean ProHeat 5207U: Why does my spot cleaner shut down after 10 minutes]]></title>
<description><![CDATA[<p>Whydoes my spot cleaner shut down after 10min</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/946454/Why+does+my+spot+cleaner+shut+down+after+10+minutes</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/946454</guid>
<pubDate>Mon, 23 Mar 2026 14:09:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Rug Doctor Carpet Extractor Wide Track 95371 2016: My machine will not stop spraying even though push button is released.]]></title>
<description><![CDATA[<p>My machine will not stop spraying even though the push button is released. It will also not spray when using the upholstery tool. I've looked through the wiring diagrams and can only quess that it maybe the rocker switch. Do you have any knowledge on this?</p>
<p>⟐ Commented maart 07, 2026 at 11:22 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/726844/My+machine+will+not+stop+spraying+even+though+push+button+is+released.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/726844</guid>
<pubDate>Sat, 07 Mar 2026 11:22:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bissell SpotBot Pet Repair: My vacuum is leaking! Please help!]]></title>
<description><![CDATA[<p>My SpotBot Pet has been a great vacuum but now it is leaking the waste fluid all over my white carpet! What can I do to stop this?</p>
<p>⟐ Commented februari 28, 2026 at 8:49 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/433146/My+vacuum+is+leaking!+Please+help!</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/433146</guid>
<pubDate>Sat, 28 Feb 2026 08:49:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Hoover Power Path Pro Advanced: Hoover pet pro max(I believe is the name)]]></title>
<description><![CDATA[<p>My Hoover carpet cleaner is working as far as cleaning the carpet but the dirty water tank is completely empty when I am done cleaning! But the carpet is not as wet!?! Where is the water going? How do I fix this?</p>
<p>⟐ Answered januari 05, 2026 at 21:28 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/768081/Hoover+pet+pro+max(I+believe+is+the+name)</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/768081</guid>
<pubDate>Mon, 05 Jan 2026 21:28:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Hoover Power Path Pro Advanced: How do you remove the lower tank with the dirty water in it?]]></title>
<description><![CDATA[<p>How do you remove the lower tank of dirty water to empty it ?</p>
<p>⟐ Answered oktober 19, 2025 at 6:35 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/921409/How+do+you+remove+the+lower+tank+with+the+dirty+water+in+it</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/921409</guid>
<pubDate>Sun, 19 Oct 2025 06:35:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Rug Doctor Carpet Cleaner PDC1R 2018: Not dispensing cleaning solutions]]></title>
<description><![CDATA[<p>Not dispensing cleaning solutions what should I look for</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/922425/Not+dispensing+cleaning+solutions</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/922425</guid>
<pubDate>Sat, 18 Oct 2025 11:29:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Carpet Cleaner: Motor runs but no lites or brushes Hoover smartwatch]]></title>
<description><![CDATA[<p>My Hoover smartwatch motor runs but no lights or brushes work</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/922402/Motor+runs+but+no+lites+or+brushes+Hoover+smartwatch</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/922402</guid>
<pubDate>Sat, 18 Oct 2025 09:18:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Hoover Power Scrub FH50150: How much is a new fuse for my hoover carpet cleaner and where is it?]]></title>
<description><![CDATA[<p>Where is the fuse for my hoover carpet cleaner located at ?</p>
<p>⟐ Commented september 21, 2025 at 15:21 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/918247/How+much+is+a+new+fuse+for+my+hoover+carpet+cleaner+and+where+is+it</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/918247</guid>
<pubDate>Sun, 21 Sep 2025 15:21:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Hoover Power Scrub FH50150: How to replace belt]]></title>
<description><![CDATA[<p>How do you open the machine to replace the belt?</p>
<p>⟐ Commented augustus 29, 2025 at 21:29 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/831543/How+to+replace+belt</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/831543</guid>
<pubDate>Fri, 29 Aug 2025 21:29:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[McCulloch MC-1275 Heavy Duty Steam Cleaner: power switch light does not come on]]></title>
<description><![CDATA[<p>Turn the steam cleaner on and nothing happens.</p>
<p>By this I mean, I have water in canister, the light</p>
<p>indicator is dormant and there is a current going</p>
<p>to steam canister.</p>
<p>⟐ Commented augustus 26, 2025 at 19:06 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/360289/power+switch+light+does+not+come+on</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/360289</guid>
<pubDate>Tue, 26 Aug 2025 19:06:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bissell SpotClean ProHeat 5207U: Leaking from the bottom]]></title>
<description><![CDATA[<p>Why does it start leaking when I connect the clean water tank? I replaced the tank and it’s still leaking as soon as I connect the tank.</p>
<p>⟐ Answered augustus 24, 2025 at 9:41 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/913697/Leaking+from+the+bottom</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/913697</guid>
<pubDate>Sun, 24 Aug 2025 09:41:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[McCulloch MC-1275 Heavy Duty Steam Cleaner: heats ,but,no pressure or steam,emptied tried cleaning instuctions. .]]></title>
<description><![CDATA[<p>same question machine heats up ,but,no pressured steam.cleaned as per instructions ?is there any :good: answers ?</p>
<p>⟐ Answered juli 27, 2025 at 7:47 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/909297/heats+,but,no+pressure+or+steam,emptied+tried+cleaning+instuctions.+.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/909297</guid>
<pubDate>Sun, 27 Jul 2025 07:47:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[McCulloch MC-1275 Heavy Duty Steam Cleaner: Steam machine won't heat up.]]></title>
<description><![CDATA[<p>When I turn on the unit, the light goes on but I don’t get any steam. I thought I put to much water in it. So I emptied unit started over, and still no steam. Is it possible the heating unit burnt out and is it something I can replace?</p>
<p>⟐ Commented juli 27, 2025 at 6:02 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/625431/Steam+machine+won&#039;t+heat+up.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/625431</guid>
<pubDate>Sun, 27 Jul 2025 06:02:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kent Carpet Cleaner C4 2012: Dropping breaker as soon as plugged in]]></title>
<description><![CDATA[<p>I have a kent c4 that's dropping breaker as soon as it's plugged in. What should be the best way to troubleshoot it and what could be possible reasons for this problem. Thanks in advance!</p>
<p>⟐ Answer edited juni 25, 2025 at 0:41 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/904948/Dropping+breaker+as+soon+as+plugged+in</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/904948</guid>
<pubDate>Wed, 25 Jun 2025 00:41:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[steam cleaner: Cap to reservoir turns freely but can’t be removed.]]></title>
<description><![CDATA[<p>I have the Wagner 0520106 Steam cleaner. I cannot remove the cap to the reservoir. It spins freely but never goes up or down. How can I remove the cap?</p>
<p>⟐ Answered mei 31, 2025 at 23:03 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/902097/Cap+to+reservoir+turns+freely+but+can%E2%80%99t+be+removed.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/902097</guid>
<pubDate>Sat, 31 May 2025 23:03:04 -0700</pubDate>
</item>
</channel>
</rss>
