<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Audio-Technica Turntables&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Audio-Technica_Turntables?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Audio-Technica Turntables&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 19 Jul 2026 12:08:56 -0700</pubDate>
<item>
<title><![CDATA[Audio-Technica AT-LP60XUSB: Start button is not doing anything]]></title>
<description><![CDATA[<p>The belt is on correctly, and the manual reset did not help. The start button does nothing; almost as if there’s no power.</p>
<p>⟐ Commented januari 27, 2024 at 18:53 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/803028/Start+button+is+not+doing+anything</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/803028</guid>
<pubDate>Sat, 27 Jan 2024 18:53:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Audio-Technica AT-LP120-USB: Lid won't stay in the up position]]></title>
<description><![CDATA[<p>The lid constantly comes back down and won't stay in the up position. I looked at the hinge and it doesn't appear to have a tension type of adjustment that was obvious. The lid has been in the down position.  I have not moved the turntable much since purchasing it. The hinges appear Ok.</p>
<p>⟐ Commented juni 02, 2026 at 10:01 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/957903/Lid+won&#039;t+stay+in+the+up+position</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/957903</guid>
<pubDate>Tue, 02 Jun 2026 10:01:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Audio-Technica AT-LP120-USB: Access and replace RCA speaker output jacks. Male ends of cable lodged]]></title>
<description><![CDATA[<p>What is best way to open turntable assembly to replace the two RCA output jacks after the male ends of the speaker cables broke off in the jacks and cannot be removed?  Also, is there a specific pair of output jacks that Audio Technica used for original and where can they be obtained for replacement ?</p>
<p>⟐ Answer edited januari 29, 2026 at 20:03 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/938334/Access+and+replace+RCA+speaker+output+jacks.+Male+ends+of+cable+lodged</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/938334</guid>
<pubDate>Thu, 29 Jan 2026 20:03:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Audio-Technica AT-LP120XUSB: How to open for service]]></title>
<description><![CDATA[<p>What Screws must be removed to open the body of it turntable ?</p>
<p>⟐ Answer edited januari 29, 2026 at 19:48 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/938335/How+to+open+for+service</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/938335</guid>
<pubDate>Thu, 29 Jan 2026 19:48:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[AT-LP60X: Tone Arm is Lifting at the beginning]]></title>
<description><![CDATA[<p>I have a AT-LP60X-BK Turntable. When I press start the tonearm moves over the record in the start position but when it drops on the record it immediately comes back up and parks and turns off. Is there an adjustment to fix this?</p>
<p>⟐ Answered oktober 31, 2025 at 14:49 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/918200/Tone+Arm+is+Lifting+at+the+beginning</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/918200</guid>
<pubDate>Fri, 31 Oct 2025 14:49:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Audio-Technica AT-LP60XUSB: brand new, never run before]]></title>
<description><![CDATA[<p>I am having the exact same issue.  This is a unit that was left, along with other AV equipment when I bought the house.  It had never had the belt engaged over the drive pully (red ribbon still attached).  I attached the pully, made sure it was right, and made the turns on the turntable.  I get the mechanical click when i press the start button, but that is the only action.  Repeated the rotating reset several times with only the click resulting.  Again, brand new, never run before.  Any ideas?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_01_27_Num_24" class="header">Update (01/27/24)</h3></div>
<p>Another YT vide showed how to manually reset but that did nothing.  With no turntable or belt on, I can make the drive pully spin if I give it a little &quot;push&quot;.  However can also stop it with very little pressure.  Once the belt is engaged, no amount of spinning the turntable will start things.  So, I have power, and the motor is not dead, but seems to lack any power.  Again, this is a never used AT-LP60.  About to chunk it.</p>
<p>⟐ Edited by author januari 28, 2024 at 13:10 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/834123/brand+new,+never+run+before</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/834123</guid>
<pubDate>Sun, 28 Jan 2024 13:10:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Audio-Technica AT-LP120XUSB: Sound is only out of the left channel]]></title>
<description><![CDATA[<p>I've tried replacing the RCA cables and using a different input in my receiver but I'm still only getting sound out of the left</p>
<p>⟐ Answered augustus 25, 2023 at 16:00 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/810108/Sound+is+only+out+of+the+left+channel</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/810108</guid>
<pubDate>Fri, 25 Aug 2023 16:00:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Audio-Technica AT-LP120XUSB: Why is the tonearm not stoping?]]></title>
<description><![CDATA[<p>When i play a record, and the songs end, it should stop before the center sticker, but it dosent and it goes in the middle</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/954107/Why+is+the+tonearm+not+stoping</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/954107</guid>
<pubDate>Sat, 09 May 2026 07:06:55 -0700</pubDate>
</item>
</channel>
</rss>
