<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Astak Security Camera&quot;]]></title>
<link>https://nl.ifixit.com/Answers/Device/Astak_Security_Camera?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Astak Security Camera&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 05 Sep 2026 00:09:42 -0700</pubDate>
<item>
<title><![CDATA[Astak Mole: Microphone does not connect to wire.]]></title>
<description><![CDATA[<p>When I took apart the camera , the Microphone was not attached to the wires. How do I fix this?</p>
<p>⟐ Answered oktober 06, 2016 at 7:58 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/342347/Microphone+does+not+connect+to+wire.</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/342347</guid>
<pubDate>Thu, 06 Oct 2016 07:58:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Astak Mole: Never completes startup routine]]></title>
<description><![CDATA[<p>Startup does a vertical and horizontal pan to the motion limits but stops part way, hesitates and begins again. I don't see how to open the mechanical or camera section of this device. I believe if I can bypass or disable this routine the camera will work.</p>
<p>⟐ Commented juni 26, 2018 at 14:48 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/294087/Never+completes+startup+routine</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/294087</guid>
<pubDate>Tue, 26 Jun 2018 14:48:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Astak Mole: Replacing Camera Rotating Lens]]></title>
<description><![CDATA[<p>Is it possible to replace the lens without replacing the entire top cap?</p>
<p>⟐ Answered oktober 06, 2016 at 7:52 MST</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/342344/Replacing+Camera+Rotating+Lens</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/342344</guid>
<pubDate>Thu, 06 Oct 2016 07:52:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Astak Mole: Initializing repeatedly and cannot connect]]></title>
<description><![CDATA[<p>When power is applied, my Astak Mole camera goes through the initialization sequence where it rotates the camera both horizontally and vertically. Before, it only does this once. Now it will do it repeatedly after a pause of about 7 seconds. It is still connecting to the hard wired ethernet cable with the assigned fixed IP verifiable via the active connections on the router. But accessing it via its IP address just times out. I also tried searching for it using the Mole Camera Setup program. It also cannot find the camera although both the PC and camera are on the same network. I called tech support at Astak and the guy told me to buy a new camera. Just like to see what folks have to say here.</p>]]></description>
<link>https://nl.ifixit.com/Answers/View/496163/Initializing+repeatedly+and+cannot+connect</link>
<guid isPermaLink="false" >https://nl.ifixit.com/Answers/View/496163</guid>
<pubDate>Tue, 26 Jun 2018 14:45:48 -0700</pubDate>
</item>
</channel>
</rss>
