Ga door naar hoofdinhoud
RCA RCT6773W22 Battery Replacement
Wat je nodig hebt
  1. RCA RCT6773W22 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 RCA RCT6773W22 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Battery Replacement: stap 2, afbeelding 1 van 3 RCA RCT6773W22 Battery Replacement: stap 2, afbeelding 2 van 3 RCA RCT6773W22 Battery Replacement: stap 2, afbeelding 3 van 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Battery Replacement: stap 3, afbeelding 1 van 3 RCA RCT6773W22 Battery Replacement: stap 3, afbeelding 2 van 3 RCA RCT6773W22 Battery Replacement: stap 3, afbeelding 3 van 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
Conclusie
Kelsea Weber
19.857 Reputatie
32 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.734 handleidingen geschreven
Één opmerking
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 3,828
