Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Nintendo Game Console Accessory te repareren, gebruik onze reparatiehandleidingen.
  1. Nintendo 64 Transfer Pak Teardown, Remove outside screws: stap 1, afbeelding 1 van 1
    • On the side where you can enter the gameboy cartridges remove the 4 screws ( These are Y screw, you can use a Y 2.0 or 2.3 head). The top cover should come of after.
  2. Nintendo 64 Transfer Pak Teardown, Remove ribbon cable and board.: stap 2, afbeelding 1 van 1
    • Pull back the 2 small plastic levers carefully. After you can eject the ribbon cable and remove the board.
  3. Nintendo 64 Transfer Pak Teardown, Remove ribbon cable from backside: stap 3, afbeelding 1 van 1
    • After the board is removed you can access the bracket that holds down the connector attached to the ribbon cable. You can remove this by unscrewing the screw on the bracket using a PH0 head
  4. Nintendo 64 Transfer Pak Teardown, Remove iron protection plate: stap 4, afbeelding 1 van 1
    • On the removed top cover from step 1 remove the 2 screw as shown with a PH0 head.
  5. Nintendo 64 Transfer Pak Teardown, Final Teardown view: stap 5, afbeelding 1 van 1
    • List of all the parts separately.
Sam Thielemans
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 365
