Inleiding
Use this guide to replace a faulty logic board in your iPhone SE.
This component is not compatible with the iPhone 5s part.
It's important to note that each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
Wat je nodig hebt
Power off your iPhone before beginning disassembly.
Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
Gereedschap gebruikt in deze stap:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Open the phone just enough to reveal the metal bracket covering the home button cable.
Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
Use the tip of a spudger to push the bracket free and remove it with tweezers.
Use the tip of a spudger to pry the home button cable connector up out of its socket.
Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray. This may require a significant amount of force.
Use a spudger to gently pry the button assembly cable up from its socket on the logic board.
92 andere personen hebben deze handleiding voltooid.
18 opmerkingen
where can I buy a logic board?
There is not much of a used market for these yet so they will be hard to come by. Most will be from dead units. You can try ebay for broken phones just be careful what you buy.
Eddie -
If the phone is dead, is ir viable to buy the logic board, or ir wont work? How can I know wich to buy? Is there an important issue or information to know obout logic boards. I will really apreciatte if someone tell me all the necessary things to know. Thanks
Were can I buy a new motherboard for iPhone se
Can i get iphone se motherboard plz
