Ga door naar hoofdinhoud
iPhone 8 Back Glass Replacement
Video overzicht
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: stap 1, afbeelding 1 van 1
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
  2. iPhone 8 Back Glass Replacement: stap 2, afbeelding 1 van 2 iPhone 8 Back Glass Replacement: stap 2, afbeelding 2 van 2
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  3. iPhone 8 Back Glass Replacement: stap 3, afbeelding 1 van 1
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
Eindstreep
13 andere personen hebben deze handleiding voltooid.
Phryne
20.446 Reputatie
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 129
Afgelopen 30 dagen: 487
Altijd: 50,854
