Inleiding
Use this guide to replace the speaker.
Wat je nodig hebt
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
Gereedschap gebruikt in deze stap:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
47 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Hi there where can I buy that small plastic blue tool you have shown to be using in the pictures above?
All the tools used in this guide are linked in the Tools section at the top. The one you're looking for can be purchased here—it has been redesigned since this guide was written, so it looks slightly different from what you see in these photos.
Changed out one of these today but the sound did not improve at all and it still sounds awful. Is there some kind of membrane between the speaker and the bottom of the phone where the holes are? Since the speaker is brand new it has to be something else making this distorted sound.
Hi, why is it necessary to remove the screen completely ?
