Ga door naar hoofdinhoud
iPhone 4S Battery Replacement
Wat je nodig hebt
  1. iPhone 4S Battery Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Remove the Bottom Pentalobe Screws next to the charger connecter.
    • It is recommended that you use a small 5-Point screwdriver.
    • Remember to make sure your iPhone is fully turned off before tearing it down, to prevent serious injury.
  2. iPhone 4S Battery Replacement, Back Panel Removal: stap 2, afbeelding 1 van 2 iPhone 4S Battery Replacement, Back Panel Removal: stap 2, afbeelding 2 van 2
    • Push the back panel towards the top edges of the iPhone. Doing this should allow the back to slide off.
    • Do NOT apply so much pressure. Especially if your iPhone is cracked.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: stap 3, afbeelding 1 van 1
    • Remove these two screws that are securing the battery connecter to the Logic Board.
    • Remember to focus and pay attention. So you don't accidentally slip and pierce the Battery!
    • For the bottom screw, it is recommended that you use a 1.5 mm Screwdriver, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: stap 4, afbeelding 1 van 1
    • Locate and pull the Plastic tab to pull out battery. Make sure to pry up outsides of battery on other sides as well.
    • Do not pull the plastic tab to hard, as it can easily rip!
  5. iPhone 4S Battery Replacement, Battery Removal: stap 5, afbeelding 1 van 1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone once its all finished.
Conclusie
60 andere personen hebben deze handleiding voltooid.
Cole Anello
1.986 Reputatie
1 Handleiding geschreven
Één opmerking
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 160
Altijd: 20,782
