Ga door naar hoofdinhoud
iPad 2 GSM Left Cellular Data Antenna Replacement
Wat je nodig hebt
  1. iPad 2 GSM Left Cellular Data Antenna Replacement, iOpener Heating: stap 1, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement, iOpener Heating: stap 1, afbeelding 2 van 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 2, afbeelding 1 van 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 3, afbeelding 1 van 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad 2 GSM Left Cellular Data Antenna Replacement, Alternate iOpener heating method: stap 4, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement, Alternate iOpener heating method: stap 4, afbeelding 2 van 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad 2 GSM Left Cellular Data Antenna Replacement, SIM Card: stap 5, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement, SIM Card: stap 5, afbeelding 2 van 2
    • Use a SIM eject tool or an uncoiled paperclip to eject the SIM card tray.
  6. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 6, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 6, afbeelding 2 van 2
    • Pull the SIM tray out of its slot and remove it from the iPad 2.
    • If replacing the SIM card, pop it out of its tray and install the new one.
  7. iPad 2 GSM Left Cellular Data Antenna Replacement, Front Panel: stap 7, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement, Front Panel: stap 7, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement, Front Panel: stap 7, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  8. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Safety Glasses
    $3.19
    Koop
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
  9. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 9, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 9, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 9, afbeelding 3 van 3
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
  10. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 10, afbeelding 1 van 1
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
  11. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 11, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 11, afbeelding 2 van 2
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
  12. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 12, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 12, afbeelding 2 van 2
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
  13. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 13, afbeelding 1 van 1
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
  14. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 14, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 14, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 14, afbeelding 3 van 3
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
  15. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 15, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 15, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 15, afbeelding 3 van 3
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  16. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 16, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 16, afbeelding 2 van 2
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
  17. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 17, afbeelding 1 van 1
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
  18. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 18, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 18, afbeelding 2 van 2
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
  19. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 19, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 19, afbeelding 2 van 2
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
  20. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 20, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 20, afbeelding 2 van 2
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
  21. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 21, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 21, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 21, afbeelding 3 van 3
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  22. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 22, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 22, afbeelding 2 van 2
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
  23. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 23, afbeelding 1 van 1
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
  24. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 24, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 24, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 24, afbeelding 3 van 3
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
  25. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 25, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 25, afbeelding 2 van 2
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
  26. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 26, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 26, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 26, afbeelding 3 van 3
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
  27. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 27, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 27, afbeelding 2 van 2
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
  28. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 28, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 28, afbeelding 2 van 2
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
  29. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 29, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 29, afbeelding 2 van 2
    Microfiber Cleaning Cloths
    $3.99
    Koop
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
  30. iPad 2 GSM Left Cellular Data Antenna Replacement, LCD: stap 30, afbeelding 1 van 1
    • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
  31. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 31, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 31, afbeelding 2 van 2
    • Lift the LCD from its long edge closest to the volume buttons and rotate it out of the rear case.
    • Lay the LCD on the front panel as seen in the second picture.
  32. iPad 2 GSM Left Cellular Data Antenna Replacement, Front Panel Assembly: stap 32, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement, Front Panel Assembly: stap 32, afbeelding 2 van 2
    • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • The retaining flaps are highlighted in red in the second picture.
  33. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 33, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 33, afbeelding 2 van 2
    • Use the edge of a plastic opening tool to peel the digitizer cable off the shields on the logic board.
    • Carefully pull the digitizer cable off the adhesive securing it to the side of the rear case.
  34. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 34, afbeelding 1 van 1
    • Pull the digitizer ribbon cable straight out of its two sockets on the logic board.
  35. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 35, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 35, afbeelding 2 van 2
    • In order to remove the front panel assembly, the ribbon cable needs to slide out between the case and the LCD. You'll need to move the LCD to make some room.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge farthest from the digitizer cable and gently flip it toward the rear case—like closing a book.
    • While holding the LCD up, gently slide the front panel away from the iPad. Be careful not to snag the digitizer cable on the rear case or LCD.
    • Set the LCD back into the body for safekeeping.
  36. iPad 2 GSM Left Cellular Data Antenna Replacement, LCD Assembly: stap 36, afbeelding 1 van 1
    • In order to work on the iPad's innards, we need to flip the LCD back out of the case.
    • Lift the LCD from its long edge closest to the volume buttons and gently flip it out of the rear case—like turning the page in a book.
    • Set the LCD face down on a clean surface. You may want to rest it on a soft cloth to prevent scratches.
  37. iPad 2 GSM Left Cellular Data Antenna Replacement, LCD Assembly: stap 37, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement, LCD Assembly: stap 37, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement, LCD Assembly: stap 37, afbeelding 3 van 3
    • Carefully lay the LCD next to the rear panel.
    • Use a plastic opening tool to lift the display data cable lock upwards.
    • Pull the display data cable out of its socket.
    • Do not pull the connector upward as you disconnect it from its socket.
  38. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 38, afbeelding 1 van 1
    • Remove the LCD assembly from the rear panel assembly.
  39. iPad 2 GSM Left Cellular Data Antenna Replacement, Headphone Jack & SIM Slot: stap 39, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement, Headphone Jack & SIM Slot: stap 39, afbeelding 2 van 2
    • Use the edge of a plastic opening tool to flip up the retaining flap on the headphone jack and front camera cable ZIF socket.
    • Be sure you are prying upward on the hinged retaining flap, not the socket itself.
    • Peel the headphone jack and front camera cable off the rear case.
  40. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 40, afbeelding 1 van 1
    • Pull the headphone jack and front camera ribbon cable straight out of its socket on the logic board.
  41. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 41, afbeelding 1 van 1
    • Remove the three 2 mm Phillips screws securing the SIM card slot to the rear panel.
  42. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 42, afbeelding 1 van 1
    • Remove the two 2.9 mm Phillips screws securing the headphone jack to the top edge of the rear panel.
  43. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 43, afbeelding 1 van 1
    • Use a plastic opening tool to help pull the headphone jack out of its recess in the top of the rear panel.
    • Don't try to remove the assembly just yet, the ribbon cables are still connected.
  44. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 44, afbeelding 1 van 1
    • Peel the front camera and microphone cables off the rear panel.
  45. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 45, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 45, afbeelding 2 van 2
    • Carefully remove the strip of tape covering the front camera cable connector.
    • Use a plastic opening tool to disconnect the front camera cable from the microphone cable immediately below it.
  46. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 46, afbeelding 1 van 1
    • Peel the front camera cable off the microphone cable.
  47. iPad 2 GSM Left Cellular Data Antenna Replacement, Front Facing Camera: stap 47, afbeelding 1 van 1
    • Remove the piece of tape highlighted in red.
    • Be careful not to damage the camera, microphone, or headphone jack ribbon cables as you remove the tape.
  48. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 48, afbeelding 1 van 1
    • Peel the front camera off the foam adhesive securing it to the rear panel.
  49. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 49, afbeelding 1 van 1
    • Pull the front facing camera cable out from the channel cut into the rear panel.
    • Remove the front facing camera from your iPad.
  50. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 50, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 50, afbeelding 2 van 2
    • Use a plastic opening tool to disconnect the microphone cable connector.
    • Remove the headphone jack/SIM slot from the device.
  51. iPad 2 GSM Left Cellular Data Antenna Replacement, Logic Board: stap 51, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement, Logic Board: stap 51, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement, Logic Board: stap 51, afbeelding 3 van 3
    • If present, remove the piece of tape covering the end of the dock connector cable.
    • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
    • Peel the dock connector ribbon cable off the rear panel.
  52. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 52, afbeelding 1 van 1
    • Place the prying tool beneath the 4 wires on the end of the connector and gently pry the speaker cable connector straight up from its socket on the logic board. Do not pry from the opposite end of the connector as this will break the 4 solder points on the underside of the socket and will require a microsolder repair.
  53. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 53, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 53, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 53, afbeelding 3 van 3
    • Use a plastic opening tool to flip up the retainer securing the upper component board cable connector to its socket on the logic board.
    • Pull the connector away from its socket on the logic board.
    • Do not lift the cable upward as you disconnect it.
  54. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 54, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 54, afbeelding 2 van 2
    • Remove the two 2.1 mm Phillips screws securing the logic board bracket to the rear case near the digitizer cable socket.
    • Remove the logic board bracket from the rear case.
  55. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 55, afbeelding 1 van 1
    • Remove the four 2.6 mm Phillips screws securing the logic and communications boards to the rear panel.
  56. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 56, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 56, afbeelding 2 van 2
    • Use a plastic opening tool to gently pry the logic board up from the rear case.
    • The logic board is adhered to the rear case; work slowly and uniformly to peel up the glue without damaging the board.
  57. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 57, afbeelding 1 van 1
    • Lift the logic board out from the rear case, and rotate it slightly toward the battery.
    • Do not try to completely remove the logic board. There are still three antenna cables attached to it.
  58. iPad 2 GSM Left Cellular Data Antenna Replacement, Left Cellular Data Antenna: stap 58, afbeelding 1 van 1
    • Use a plastic opening tool to disconnect the cellular data antenna cable from its socket on the communications board.
  59. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 59, afbeelding 1 van 1
    • Remove the single 2.1 mm Phillips screw securing the cellular data antenna cable to the rear case.
  60. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 60, afbeelding 1 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 60, afbeelding 2 van 3 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 60, afbeelding 3 van 3
    • In this step you will remove the two pieces of tape securing the cellular data antenna cable to the rear case.
    • Use the tip of a spudger to remove the two pieces of tape.
  61. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 61, afbeelding 1 van 1
    • Gently pry the cellular data antenna from the rear case with a plastic opening tool.
  62. iPad 2 GSM Left Cellular Data Antenna Replacement: stap 62, afbeelding 1 van 2 iPad 2 GSM Left Cellular Data Antenna Replacement: stap 62, afbeelding 2 van 2
    • Lift the cellular data antenna out of its recess in the iPad casing.
    • Gently pull the cellular data antenna cable through the channel cut in the rear panel, and remove the antenna from the device.
Conclusie
To reassemble your device, follow these directions in reverse and use our iPad 2 GSM Front Panel Adhesive strips guide to reattach the front panel.
17 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
503.578 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.524 handleidingen geschreven
Één opmerking
it's not that hard -- the hardest part is removing the original digitizer. WEAR EYE PROTECTION-- glass will fly, you don't want to spend thousands on a blocked tear duct surgery.
Elpoep - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 17,891
