Ga door naar hoofdinhoud
iMac Intel 27" EMC 2429 Graphics Card, CPU, Hard Drive, Ram Upgrade
Wat je nodig hebt
    • First Start by unplugging all cables from your iMac and setting up a workstation.
    • You will need a large workstation to hold the iMac and it's parts.
  1. Gereedschap gebruikt in deze stap:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Koop
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Electronic Cartel
85 Reputatie
1 Handleiding geschreven
3 opmerkingen
Where is the rest of this guide?
Andrew Gannon - Antwoord
Obviously not following this guide, I opened my iMac that had full graphics failure, uninstalled the GPU-card, cleaned it, baked it in the oven to soften the solder and let the chip reattach itself, added new conductive paste, reinstalled it and it worked again.
I can't remember the temperatures, but there are tutorials to be found.
Bernhard - Antwoord
Non è una guida. Manca tutto!
Giacomo Santerini - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 97
Afgelopen 30 dagen: 379
Altijd: 2,062
