Ga door naar hoofdinhoud
Xbox Hard Drive Management
Wat je nodig hebt
  1. Xbox Hard Drive Management, Xbox Hard Drive Management: stap 1, afbeelding 1 van 1
    • Boot up your Xbox without a disc in the drive and you will get the dashboard. Head to "Memory", as the Xbox doesn't have a single format HD option.
  2. Xbox Hard Drive Management: stap 2, afbeelding 1 van 1
    • Here you can see the Xbox hard drive options. Select the save you want to delete, and hit A.
  3. Xbox Hard Drive Management: stap 3, afbeelding 1 van 1
    • Press A to delete the save. Then go back and delete all the other saves you want to delete. Now your Xbox HD is completely clear of savegames.
    • If you're selling your Xbox, go to Settings and turn off auto-login and go to Xbox LIVE and remove your account options.
Conclusie
Make sure you haven't left any music on your Xbox HD if you're selling your Xbox.
20 andere personen hebben deze handleiding voltooid.
Eddie Meehan
894 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 77
Altijd: 11,248
