Ga door naar hoofdinhoud
Toy Windmill Repair
Wat je nodig hebt
  1. Toy Windmill Repair, Toy Windmill Repair: stap 1, afbeelding 1 van 1
    • Use the 120 grit sandpaper to remove any rough edges on both the base unit and any parts which need to be connected to it.
  2. Toy Windmill Repair: stap 2, afbeelding 1 van 1
    • Use the rough sandpaper on parts that need to be connected to the primary unit as this will result in greater surface contact.
  3. Toy Windmill Repair: stap 3, afbeelding 1 van 2 Toy Windmill Repair: stap 3, afbeelding 2 van 2
    • Apply a small amount of wood glue to each end.
    • Connect the two pieces and apply a small amount of masking tape to hold them in place.
  4. Toy Windmill Repair: stap 4, afbeelding 1 van 1
    • Once all the pieces have been connected and the glue has cured, use the fine sandpaper to smooth out the connected pieces.
  5. Toy Windmill Repair: stap 5, afbeelding 1 van 1
    • Using the fill stick crayon, blend in the connected pieces.
    • This will require the reader to be creative.
  6. Toy Windmill Repair: stap 6, afbeelding 1 van 2 Toy Windmill Repair: stap 6, afbeelding 2 van 2
    • Apply a small amount of wood glue to each end of the windmill.
    • Connect the two pieces and apply a small amount of masking tape to hold the two ends in place.
Conclusie
To reassemble your device, follow these instructions in order.
Karim Ladha
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 306
