Ga door naar hoofdinhoud
Torn-Off Backpack Shoulder Strap Repair
Wat je nodig hebt
  1. Torn-Off Backpack Shoulder Strap Repair, Torn-Off Backpack Shoulder Strap Repair: stap 1, afbeelding 1 van 1
    • Thread the needle with the 0.7 yards of upholstery nylon thread.
  2. Torn-Off Backpack Shoulder Strap Repair: stap 2, afbeelding 1 van 3 Torn-Off Backpack Shoulder Strap Repair: stap 2, afbeelding 2 van 3 Torn-Off Backpack Shoulder Strap Repair: stap 2, afbeelding 3 van 3
    • Align the two ends of the thread, and tie a knot.
    • Trim the extra thread off.
  3. Torn-Off Backpack Shoulder Strap Repair: stap 3, afbeelding 1 van 2 Torn-Off Backpack Shoulder Strap Repair: stap 3, afbeelding 2 van 2
    • Trim the frayed edges and thread off of the backpack and shoulder strap.
  4. Torn-Off Backpack Shoulder Strap Repair: stap 4, afbeelding 1 van 2 Torn-Off Backpack Shoulder Strap Repair: stap 4, afbeelding 2 van 2
    • Align the 2x5 nylon cloth with the torn off backpack strap.
    • Make sure that the nylon cloth is able to fold over the strap, and align up with the other end.
  5. Torn-Off Backpack Shoulder Strap Repair: stap 5, afbeelding 1 van 2 Torn-Off Backpack Shoulder Strap Repair: stap 5, afbeelding 2 van 2
    • Begin sewing across the handle with the backstitching sewing technique.
    • Make sure that the stitch goes all the way through the Nylon as you sew.
    • The second picture of this step did not satisfy the second part of this step.
  6. Torn-Off Backpack Shoulder Strap Repair: stap 6, afbeelding 1 van 3 Torn-Off Backpack Shoulder Strap Repair: stap 6, afbeelding 2 van 3 Torn-Off Backpack Shoulder Strap Repair: stap 6, afbeelding 3 van 3
    • To end the stitch, push the needle about halfway through.
    • Take the thread, and wrap it around the sharp side of the needle.
    • Pull the needle all the way through.
    • If the stitch did not go through both sides of the nylon, repeat steps 5 and 6 over on the other side. Remember to replace the thread by repeating steps 1 and 2.
    • If you want extra support, repeat steps 5 and 6 on the other side. Remember to replace the thread by repeating steps 1 and 2.
  7. Torn-Off Backpack Shoulder Strap Repair: stap 7, afbeelding 1 van 1
    • Cut the thread, and remove the thread from the needle.
    • Repeat steps 1 and 2 with the 1 meter long thread.
  8. Torn-Off Backpack Shoulder Strap Repair: stap 8, afbeelding 1 van 3 Torn-Off Backpack Shoulder Strap Repair: stap 8, afbeelding 2 van 3 Torn-Off Backpack Shoulder Strap Repair: stap 8, afbeelding 3 van 3
    • Align the handle with the shoulder of the backpack.
    • Secure the handle in place by applying pressure, and then begin sewing with the backstitching sewing technique.
    • When sewing, make sure to follow your thread and needle carefully. A misguided needle will lead to unwanted tangles.
    • End the stitch by repeating step 6.
  9. Torn-Off Backpack Shoulder Strap Repair: stap 9, afbeelding 1 van 1
    • Trim off any frayed edges or loose string.
Conclusie
After preceding through all the steps, you should now have a durable, functional backpack! If parts of the strap begin ripping, you can repair the tear by applying the backstitching sewing technique anywhere!
14 andere personen hebben deze handleiding voltooid.
Emily
607 Reputatie
1 Handleiding geschreven
Cal Poly, Team 28-1, Green Spring 2015 Lid van Cal Poly, Team 28-1, Green Spring 2015
CPSU-GREEN-S15S28G1
4 Leden
8 handleidingen geschreven
2 opmerkingen
Emily your tutorial is great the photos are great
thank you. . . !
I know how much work goes into making a tutorial like this
nazo - Antwoord
Outstanding instructional! Thank you tho for hands down the best tutorial ive come across all day! TY for not starting off with 2 pages of your life story in the beginning too for real. great job with the instructions- easy to follow and to the point. I loved that there were a few pics in each step that if you glided over one of the images, it would highlight and enlarge as the main photo/step. extremely helpful and easy to guide through:) Also, can i just cut a small slice the size of strap through the bag at top and stick the strap end in and hand sew ? or do i have to have another piece of fabric sewn onto the strap to be able to do that....? i am trying to make it look like the strap never broke/was not repaired ya know? Than'Q!
Brit Leaf - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 228
Afgelopen 30 dagen: 1,084
Altijd: 158,914
