Ga door naar hoofdinhoud
System76 Serval WS Cooling Fan Replacement
Wat je nodig hebt
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 1 van 1
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
  2. System76 Serval WS Cooling Fan Replacement: stap 2, afbeelding 1 van 2 System76 Serval WS Cooling Fan Replacement: stap 2, afbeelding 2 van 2
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
  3. System76 Serval WS Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
  4. System76 Serval WS Cooling Fan Replacement: stap 4, afbeelding 1 van 2 System76 Serval WS Cooling Fan Replacement: stap 4, afbeelding 2 van 2
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
Conclusie
Oliver Anderson
289 Reputatie
3 handleidingen geschreven
Één opmerking
What model of fan would one buy to replace this?
CrustyTrombone - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 628
