Ga door naar hoofdinhoud
Sony Xperia Z2 Earpiece Replacement
Wat je nodig hebt
Video overzicht
  1. Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: stap 1, afbeelding 1 van 3 Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: stap 1, afbeelding 2 van 3 Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: stap 1, afbeelding 3 van 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Earpiece Replacement: stap 2, afbeelding 1 van 3 Sony Xperia Z2 Earpiece Replacement: stap 2, afbeelding 2 van 3 Sony Xperia Z2 Earpiece Replacement: stap 2, afbeelding 3 van 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Earpiece Replacement: stap 3, afbeelding 1 van 2 Sony Xperia Z2 Earpiece Replacement: stap 3, afbeelding 2 van 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Earpiece Replacement, Battery: stap 4, afbeelding 1 van 3 Sony Xperia Z2 Earpiece Replacement, Battery: stap 4, afbeelding 2 van 3 Sony Xperia Z2 Earpiece Replacement, Battery: stap 4, afbeelding 3 van 3
  5. Sony Xperia Z2 Earpiece Replacement, Logic Board: stap 5, afbeelding 1 van 2 Sony Xperia Z2 Earpiece Replacement, Logic Board: stap 5, afbeelding 2 van 2
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
  6. Sony Xperia Z2 Earpiece Replacement: stap 6, afbeelding 1 van 3 Sony Xperia Z2 Earpiece Replacement: stap 6, afbeelding 2 van 3 Sony Xperia Z2 Earpiece Replacement: stap 6, afbeelding 3 van 3
  7. Sony Xperia Z2 Earpiece Replacement, Earpiece: stap 7, afbeelding 1 van 1
Conclusie
7 andere personen hebben deze handleiding voltooid.
ZFix
191.647 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.498 handleidingen geschreven
3 opmerkingen
Would be nice with a comment on how to remove the earpiece.
Since the phone is waterresistance the headjack and earpiece are taped to the body which makes that you need to buy a new sparepart, but look out on ebay that you get a part with tape to it.
Claes - Antwoord
After having done the removal of the earpiece you will have to, either buy a new adhesive for the earpice or a new earpiece. But be aware some spareparts are sold without adhesive.
Claes -
I accidentally torn apart one of the cables( vibrate cable:the brown one) I'm messed up! Vibration not working. What can I do? Where can I buy one of those cables? Please reply!
Mahtab - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 7,624
