Ga door naar hoofdinhoud
Repairing Vehicle Headliner
Wat je nodig hebt
  1. Repairing Vehicle Headliner, Repairing Vehicle Headliner: stap 1, afbeelding 1 van 1
    • Prep the car for work.
    • Disconnect the negative battery terminal.
    • Removal of the right passenger seat may be necessary to help remove the headliner from the car.
    • Remove the trim.
    • Unbolt the sun visors, dome lamp, grab handles and any other accessories that are attached to the ceiling.
    • Remove the upper seat belt mounting loops.
    • Remove and/or pull back just enough of the side interior trim panels to gain access to the edge of the headliner. Complete removal of these panels is usually not needed.
    • Lower one side of the headliner panel and slide it over to clear the trim panels.
    • Turn the panel and remove it from the vehicle.
  2. Repairing Vehicle Headliner: stap 3, afbeelding 1 van 2 Repairing Vehicle Headliner: stap 3, afbeelding 2 van 2
    • Remove the old fabric from the board.
    • Place the headliner panel on a clean work table.
    • Carefully pull the old fabric material off the board. Usually the foam backing will remain stuck to the headliner board. Use a piece of the old material to rub the old foam loose from the board.
    • Vacuum the foam bits from the backing board.
  3. Repairing Vehicle Headliner: stap 4, afbeelding 1 van 3 Repairing Vehicle Headliner: stap 4, afbeelding 2 van 3 Repairing Vehicle Headliner: stap 4, afbeelding 3 van 3
    • Install new fabric:
    • If the board is damaged, repair it using aluminum tape. Any rough areas might show after the new fabric is applied.
    • Lay out the new fabric over the board. Pull 1/2 of it back over itself.
    • Spray headliner adhesive glue on 1/2 of the board and the back side of the fabric.
    • Carefully place the fabric onto the board starting from the center point and smooth it outward wit your hand as you lay it down.
    • Pull up the other 1/2of the fabric over the side you just glued down. Repeat the above steps to lay down this side of the fabric.
  4. Repairing Vehicle Headliner: stap 5, afbeelding 1 van 3 Repairing Vehicle Headliner: stap 5, afbeelding 2 van 3 Repairing Vehicle Headliner: stap 5, afbeelding 3 van 3
    • Trim up the fabric edges
    • Fold over the front & rear edges and glue them to the back side of the board about 1 inch from the edge.
    • Cut the side edges flush with the board. Also cut any access holes for the sun visors and other accessories that were previously removed.
  5. Repairing Vehicle Headliner: stap 6, afbeelding 1 van 3 Repairing Vehicle Headliner: stap 6, afbeelding 2 van 3 Repairing Vehicle Headliner: stap 6, afbeelding 3 van 3
    • Reinstall the headliner to the car:
    • Reverse the removal steps to re-install the headliner into the car.
    • Start one edge over the side trim panels and then raise the headliner into position over the other side trim panels.
    • Re-install the sun visors, dome lamp, seat belt upper loops and any other items that were previously removed
    • Lightly brush the headliner to remove marks & fingerprints.
    • If any of the trim clips break off of the interior trim panels, you can reattach them to the panel with 2-part epoxy glue.
Conclusie
16 andere personen hebben deze handleiding voltooid.
HemiBill
3.092 Reputatie
2 handleidingen geschreven
3 opmerkingen
Excellent directions. I'd like to see a well made video of the procedure! Thanks,
Dub
bullfeather - Antwoord
Thank you so much. I've never tried anything like this before, you've made it seem like even I can do it. I'm excited to save a cpl hundred by doing it myself!
Patti L Walton - Antwoord
I like the steps you laid out. Its a very easy job of you have patience. Its a virtue in itself. All headliners are made different and from different material. Thank you for sharing this,
Michael Smith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 131
Altijd: 81,889
