Ga door naar hoofdinhoud
Repair Loose Floorboard Carpet in Vehicle
Wat je nodig hebt
  1. Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: stap 1, afbeelding 1 van 2 Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: stap 1, afbeelding 2 van 2
    • Pull back detached carpet from the floorboard to determine how much carpet is detached.
  2. Repair Loose Floorboard Carpet in Vehicle: stap 2, afbeelding 1 van 2 Repair Loose Floorboard Carpet in Vehicle: stap 2, afbeelding 2 van 2
    • Apply a generous layer of spray adhesive to floorboard.
    • Wear a mask to prevent inhalation of fumes.
    • Wear gloves to prevent the adhesive from sticking to your hands.
    • Perform repair in a well ventilated area.
  3. Repair Loose Floorboard Carpet in Vehicle: stap 3, afbeelding 1 van 1
    • Allow 15-30 seconds for adhesive to dry before attaching carpet to floorboard.
  4. Repair Loose Floorboard Carpet in Vehicle: stap 4, afbeelding 1 van 2 Repair Loose Floorboard Carpet in Vehicle: stap 4, afbeelding 2 van 2
    • Apply carpet to floorboard firmly using hands.
    • This step needs to be repeated until carpet is in place with no wrinkles or bulges.
  5. Repair Loose Floorboard Carpet in Vehicle: stap 5, afbeelding 1 van 2 Repair Loose Floorboard Carpet in Vehicle: stap 5, afbeelding 2 van 2
    • Use a plastic squeegee to tuck the corner of the carpet into the paneling of the floorboard.
  6. Repair Loose Floorboard Carpet in Vehicle: stap 6, afbeelding 1 van 1
    • Vacuum floorboard to remove any debris or dirt.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tedra Levatte
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 145
Altijd: 6,351
