Ga door naar hoofdinhoud
Quantum View 10.1 camera Replacement
Wat je nodig hebt
  1. Quantum View 10.1 camera Replacement, Open Quantum View case: stap 1, afbeelding 1 van 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: stap 2, afbeelding 1 van 2 Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: stap 2, afbeelding 2 van 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 camera Replacement, Unhooking the battery: stap 3, afbeelding 1 van 2 Quantum View 10.1 camera Replacement, Unhooking the battery: stap 3, afbeelding 2 van 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    • Remove yellow plastic and carefully pull clip away from connection.
  4. Quantum View 10.1 camera Replacement, Remove camera clip: stap 5, afbeelding 1 van 2 Quantum View 10.1 camera Replacement, Remove camera clip: stap 5, afbeelding 2 van 2
    • Remove yellow tape.
    • Unclip ribbon connector.
  5. Quantum View 10.1 camera Replacement, Remove camera: stap 6, afbeelding 1 van 2 Quantum View 10.1 camera Replacement, Remove camera: stap 6, afbeelding 2 van 2
    • Unscrew plastic camera holder using a PH00 screwdriver bit.
    • Release the plastic holder tab and remove camera.
Conclusie
stephen Munchinsky
786 Reputatie
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 165
