Ga door naar hoofdinhoud
PowerBook G4 Titanium DVI RAM Replacement
Wat je nodig hebt
  1. PowerBook G4 Titanium DVI RAM Replacement, Battery: stap 1, afbeelding 1 van 2 PowerBook G4 Titanium DVI RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI RAM Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  3. PowerBook G4 Titanium DVI RAM Replacement: stap 3, afbeelding 1 van 1
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
  4. PowerBook G4 Titanium DVI RAM Replacement: stap 4, afbeelding 1 van 1
    • Your laptop should look approximately like this.
  5. PowerBook G4 Titanium DVI RAM Replacement, RAM: stap 5, afbeelding 1 van 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 14,694
