Ga door naar hoofdinhoud
PowerBook G3 Lombard Heat Shield Replacement
Wat je nodig hebt
  1. PowerBook G3 Lombard Heat Shield Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Heat Shield Replacement: stap 2, afbeelding 1 van 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Heat Shield Replacement: stap 3, afbeelding 1 van 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Heat Shield Replacement, Heat Shield: stap 4, afbeelding 1 van 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Heat Shield Replacement: stap 5, afbeelding 1 van 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Heat Shield Replacement: stap 6, afbeelding 1 van 1
    • Your laptop should look approximately like this.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 2,555
