Ga door naar hoofdinhoud
Power Mac G4 M5183 Main Fan Replacement
Wat je nodig hebt
  1. Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: stap 1, afbeelding 1 van 2 Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: stap 1, afbeelding 2 van 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Main Fan Replacement, Main Fan: stap 2, afbeelding 1 van 2 Power Mac G4 M5183 Main Fan Replacement, Main Fan: stap 2, afbeelding 2 van 2
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Power Mac G4 M5183 Main Fan Replacement: stap 3, afbeelding 1 van 1
    • Remove the power cable from the fan and detach bracing.
  4. Power Mac G4 M5183 Main Fan Replacement, Main Fan: stap 4, afbeelding 1 van 1
    • To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Stephen Scruggs
2.238 Reputatie
2 handleidingen geschreven
Cal Poly, Team 13-24, Maness Winter 2010 Lid van Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Leden
25 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 7,740
