Ga door naar hoofdinhoud
Polaroid Now i-Type Film Pack Replacement
Wat je nodig hebt
Video overzicht
  1. Polaroid Now i-Type Film Pack Replacement, Open The Film Pack Door: stap 1, afbeelding 1 van 2 Polaroid Now i-Type Film Pack Replacement, Open The Film Pack Door: stap 1, afbeelding 2 van 2
    • Open the door using the eject button on the side of the Polaroid Now camera make sure to hold the camera in such a way as to not obstruct the film door hinge
  2. Polaroid Now i-Type Film Pack Replacement, (Optional)* Take Out Old Film: stap 2, afbeelding 1 van 2 Polaroid Now i-Type Film Pack Replacement, (Optional)* Take Out Old Film: stap 2, afbeelding 2 van 2
    • If there is an empty film pack in your camera take it out using the sides of the pack or the rainbow tab on the film.
    • If you know that there is still film in the pack note that the exposure/photo will be exposed and will not show a photo if you put said film pack back in the camera at a later time.
    • *Normally there is no film pack in the camera when you open the door so you may skip this step.
  3. Polaroid Now i-Type Film Pack Replacement, Insert New i-Type Film Pack: stap 3, afbeelding 1 van 2 Polaroid Now i-Type Film Pack Replacement, Insert New i-Type Film Pack: stap 3, afbeelding 2 van 2
    • The film pack comes in a silver-plastic wrapping, take this off by ripping it and throw away/recycle it.
    • Now, insert the film into the camera with the dark slide up and the rainbow tab facing towards you. Make sure to not squish the film as this may expose/ beak the chemical packet in the film.
    • Push pack in firmly until you hear a click.
    • Film Types Supported By Polaroid Now: - i-Type Color - i-Type B&W - Vintage Polaroid 600 Film - Modern Polaroid 600, Special Edition, B&W, Monochrome and, Circular - Polaroid SX-70 (FILM WILL BE UNDEREXPOSED AND BAD, FOR USE IN A PINCH)
    • Make Sure You Hear A Click
    • Push the film pack in and when you close the door make sure your hands are not in the way of the film eject slot, watch as the dark slide ejects, flick the frog younger up and take the Darkslide out. You are now ready to take pictures.
    • Refer to Step 3 for removing the pack once you are done.
Eindstreep
Trstnnexus123
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 253
Altijd: 1,288
