Ga door naar hoofdinhoud
Nokia Lumia 635 630 Display Assembly Replacement with Frame
Wat je nodig hebt
Video overzicht
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: stap 1, afbeelding 1 van 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: stap 1, afbeelding 2 van 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: stap 1, afbeelding 3 van 3
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: stap 2, afbeelding 1 van 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: stap 2, afbeelding 2 van 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: stap 2, afbeelding 3 van 3
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: stap 3, afbeelding 1 van 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: stap 3, afbeelding 2 van 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: stap 3, afbeelding 3 van 3
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: stap 4, afbeelding 1 van 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: stap 4, afbeelding 2 van 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: stap 4, afbeelding 3 van 3
    • Put the earpiece on the new display assembly and start with reassembling.
Conclusie
17 andere personen hebben deze handleiding voltooid.
ZFix
191.674 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.512 handleidingen geschreven
2 opmerkingen
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - Antwoord
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 10,352
