Ga door naar hoofdinhoud
Model O- Mouse Cable Replacement
Wat je nodig hebt
  1. Model O- Mouse Cable Replacement, Mouse Cable: stap 1, afbeelding 1 van 3 Model O- Mouse Cable Replacement, Mouse Cable: stap 1, afbeelding 2 van 3 Model O- Mouse Cable Replacement, Mouse Cable: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Turn the mouse over so that the feet are facing you.
    • Remove the bottom two mouse feet using tweezers.
    • If you plan on reusing the mouse feet place them with the adhesive side up.
  2. Model O- Mouse Cable Replacement: stap 2, afbeelding 1 van 2 Model O- Mouse Cable Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
  3. Model O- Mouse Cable Replacement: stap 3, afbeelding 1 van 3 Model O- Mouse Cable Replacement: stap 3, afbeelding 2 van 3 Model O- Mouse Cable Replacement: stap 3, afbeelding 3 van 3
    • Slide the base away from the top housing to avoid the front clips.
    • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
    • Avoid putting strain on the thin LED ribbon cables.
  4. Model O- Mouse Cable Replacement: stap 4, afbeelding 1 van 2 Model O- Mouse Cable Replacement: stap 4, afbeelding 2 van 2
    • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
    • Do not pull on the wires.
    • Remove the cable from around the circuit board and from the hole on the front of the mouse.
  5. Model O- Mouse Cable Replacement: stap 5, afbeelding 1 van 2 Model O- Mouse Cable Replacement: stap 5, afbeelding 2 van 2
    • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
    • Do not push on the wires.
  6. Model O- Mouse Cable Replacement: stap 6, afbeelding 1 van 2 Model O- Mouse Cable Replacement: stap 6, afbeelding 2 van 2
    • Route the new cable through the slit in the circuit board.
    • Route the new cable behind the pillars.
    • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
    • The cable may not stay in place until the top housing is securely fastened back on.
  7. Model O- Mouse Cable Replacement: stap 7, afbeelding 1 van 2 Model O- Mouse Cable Replacement: stap 7, afbeelding 2 van 2
    • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
    • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
  8. Model O- Mouse Cable Replacement: stap 8, afbeelding 1 van 1
    • Screw the two screws back in with a Phillips #0 screwdriver.
    • Do not apply too much force or you risk stripping the screw holes.
  9. Model O- Mouse Cable Replacement: stap 9, afbeelding 1 van 2 Model O- Mouse Cable Replacement: stap 9, afbeelding 2 van 2
    • Reapply the mouse feet with the adhesive side sticking to the mouse.
    • There are plastic ridges to help guide the user where to place the mouse feet.
    • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Theo SW
241 Reputatie
1 Handleiding geschreven
2 opmerkingen
Where can I get the replacement cable for it?
Ekke Sten - Antwoord
does glorius them selfs sell replacment parts ?
aniss-97 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 196
Altijd: 11,111
