Ga door naar hoofdinhoud
Microsoft Kinect Tilt Motor Replacement
Wat je nodig hebt
  1. Microsoft Kinect Tilt Motor Replacement, Tilt Motor: stap 1, afbeelding 1 van 1
    • Pull the rubber backing off the base of the Kinect.
    • If the adhesive attaching the rubber backing and the base doesn't come off with the rubber backing, remove the adhesive as well.
    • If the adhesive comes off separately, you may some type of adhesive to reattach the rubber backing.
  2. Microsoft Kinect Tilt Motor Replacement: stap 2, afbeelding 1 van 2 Microsoft Kinect Tilt Motor Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the four 7mm T6 Torx screws.
    • Pull off the base to reveal the inner case.
  3. Microsoft Kinect Tilt Motor Replacement: stap 3, afbeelding 1 van 3 Microsoft Kinect Tilt Motor Replacement: stap 3, afbeelding 2 van 3 Microsoft Kinect Tilt Motor Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the four 5mm #0 Phillip screws.
    • These screws strip easily.
    • Remove the metal plate to reveal the motor and gears.
    • Disconnect the connector to separate the plate from the Kinect.
  4. Microsoft Kinect Tilt Motor Replacement: stap 4, afbeelding 1 van 1
    • Remove the three gears on top of the motor, starting with the center gear.
  5. Microsoft Kinect Tilt Motor Replacement: stap 5, afbeelding 1 van 2 Microsoft Kinect Tilt Motor Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the four 5mm #00 Phillip screws.
    • Remove the motor from the plate to replace.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Daniel
341 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-7, Amido Spring 2015 Lid van Cal Poly, Team 14-7, Amido Spring 2015
CPSU-AMIDO-S15S14G7
4 Leden
6 handleidingen geschreven
2 opmerkingen
Be careful not to lose the spring & washer ! ( It’s also missing a step showing where the brass washer goes )https://www.zdnet.com/pictures/microsoft...
Bantum Works - Antwoord
So far the isn’t a mention replacement of the plastic “post” that the tilt motor and the upper sensor unit are joined at. Mine broke (that’s what happens when you get a “free Xbox 360” at a neighborhood moving sale.) I couldn’t get the base plate apart as my T5 torx bit is trashed. So, my solution?…epoxy the heck out of the post as it’s only purpose is to hold the two units of the Kinect together. So far it worked!
David C - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 43
Altijd: 4,505
