Ga door naar hoofdinhoud
Magic Trackpad Battery Replacement
Wat je nodig hebt
  1. Magic Trackpad Battery Replacement, Batteries: stap 1, afbeelding 1 van 2 Magic Trackpad Battery Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Use a spudger or coin to twist out the battery door.
  2. Magic Trackpad Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide out the two AA batteries.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ronnie
3.522 Reputatie
5 handleidingen geschreven
4 opmerkingen
Hello there, is the Trackpad destroyed by misplacing (wrong polarity) the batteries?
Toto1411 - Antwoord
I recently found a Magic Trackpad on a junk pile, to find that the batteries are corroded and won’t come out.
I poured a small amount of isopropyl alcohol in the battery cylider, pried with a thin plastic pick and banged it against a table to get out the first battery, but the second one doesn’t want to move.
Any suggestions for how to get it out without destroying the device? The only thing I can think of would be to crazy-glue a thin rod to the top of the battery, maybe pour in some alcohol, and pull/wiggle the battery until it comes out. I’m afraid that any kind of stronger solvent will cause real damage.
Opinions?
shamino - Antwoord
The best solvent for leaked alkaline batteries is… tap water!
michel.firholz -
I had corroded batteries in my Magic Keyboard. Exact same construction. I fashioned a thin blade from an aluminum can. It had enough column strength to slide between the battery and the aluminum battery compartment and with different solvents I was able to free the batteries. Now I have a trackpad that I am trying to recondition but not so easy. IPA and WD40 did not free the batteries this time, about to try dilute vinegar.
Eric Andersen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 96
Altijd: 12,673
