Inleiding
Replace the missing feet for your MacBook Pro 17".
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
Align the new foot inside the foot pad.
Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
To reassemble the device, replace the lower case and all of the screws.
9 andere personen hebben deze handleiding voltooid.
