Ga door naar hoofdinhoud
MacBook Pro 15" Unibody Mid 2010 Right Fan Replacement
Wat je nodig hebt
  1. MacBook Pro 15" Unibody Mid 2010 Right Fan Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 Right Fan Replacement: stap 2, afbeelding 1 van 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2010 Right Fan Replacement, Right Fan: stap 3, afbeelding 1 van 1
    • Remove three T6 Torx screws securing the right fan to the logic board and upper case.
  4. MacBook Pro 15" Unibody Mid 2010 Right Fan Replacement: stap 4, afbeelding 1 van 3 MacBook Pro 15" Unibody Mid 2010 Right Fan Replacement: stap 4, afbeelding 2 van 3 MacBook Pro 15" Unibody Mid 2010 Right Fan Replacement: stap 4, afbeelding 3 van 3
    • Use a spudger to pry the fan connector straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  5. MacBook Pro 15" Unibody Mid 2010 Right Fan Replacement: stap 5, afbeelding 1 van 1
    • Lift the right fan out of the upper case.
Conclusie
59 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 31,162
