Ga door naar hoofdinhoud
MacBook Pro 13" Unibody Mid 2010 Key Cap Removal
  1. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Identify the Keyboard Key: stap 1, afbeelding 1 van 1
    • The small lug that holds the button's hinge pin is clearly visible in the circled area, and the other half of the pair is pointed to by the arrow.
    • The video demonstrates how to insert the blade of a knife carefully behind the lug and push it in far enough for the pin to clear the lug.
    • Depending on the tool you use, be careful not to damage the plastic of the keys or the key's hinge mechanism.
  2. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Remove the Key: stap 3, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Remove the Key: stap 3, afbeelding 2 van 2
    • Once the key is freed from the left side mechanism, it is still connected on the right side.
    • Release the key by rotating it counterclockwise with a tool or your fingers.
  3. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal: stap 4, afbeelding 1 van 1
    • Unclip the lever arm by carefully inserting a spatula or a knife (be careful, the metal can damage the fingerboard).
    • Detach the white part of the key. Take this opportunity to clean any dust or debris from the key or the hinge mechanism.
  4. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Reassembling the Hinge Mechanism: stap 5, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Reassembling the Hinge Mechanism: stap 5, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Reassembling the Hinge Mechanism: stap 5, afbeelding 3 van 3
    • Insert the hinge (framed in the photo) into the metal slot in the keyboard as shown in the second photo.
    • The third photo shows the hinge mechanism properly in place.
  5. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Insert the Hinge Pins: stap 6, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Insert the Hinge Pins: stap 6, afbeelding 2 van 2
    • As shown in the photo, reinsert the hinge's pin into the metal lug on both sides.
  6. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal: stap 7, afbeelding 1 van 1
    • The final step is to place the key on the hinge mechanism and press hard on it so that the key clicks into place; the sound of the clips locking will be perceptible. There are four clips holding the key cap.
Conclusie
Congratulations; you can now remove and replace most any key on the keyboard.
4 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Alexandra Lem
423 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 94
Afgelopen 30 dagen: 395
Altijd: 3,663
