Ga door naar hoofdinhoud
MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Remove the lower case screws: stap 1, afbeelding 1 van 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Lift the lower case away: stap 2, afbeelding 1 van 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Battery: stap 3, afbeelding 1 van 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Fan: stap 4, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Fan: stap 4, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Fan: stap 4, afbeelding 3 van 3
    • Use a spudger to pry the fan connector out of its seat, and straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  5. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 5, afbeelding 1 van 1
    • Remove the following three screws securing the fan to the upper case:
    • One 6.5 mm Phillips.
    • One 5.5 mm Phillips.
    • One 4.5 mm Phillips.
  6. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 6, afbeelding 1 van 1
    • Lift the fan out of the upper case.
  7. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Logic Board: stap 7, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Logic Board: stap 7, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, Logic Board: stap 7, afbeelding 3 van 3
    • Grab the plastic pull tab secured to the display data cable lock, and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer.
  8. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 8, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 8, afbeelding 2 van 2
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7 mm Phillips.
    • One 5 mm Phillips.
    • Lift the display data cable bracket out of the upper case.
  9. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 9, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
  10. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 10, afbeelding 1 van 1
    • In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  11. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 11, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 11, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 11, afbeelding 3 van 3
    • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
  12. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 12, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 12, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 12, afbeelding 3 van 3
    • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
    • Use your spudger to slide the keyboard ribbon cable out of its socket.
  13. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 13, afbeelding 1 van 1
    • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
  14. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 14, afbeelding 1 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 14, afbeelding 2 van 3 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 14, afbeelding 3 van 3
    • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
    • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
  15. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 15, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
  16. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 16, afbeelding 1 van 1
    • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
  17. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 17, afbeelding 1 van 1
    • Remove the following screws:
    • Five 3.1 mm Phillips.
    • Two 3.9 mm Phillips.
    • Two 7 mm Phillips from the DC-in board.
  18. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 18, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 18, afbeelding 2 van 2
    • Remove the following Tri-point screws securing the battery to the upper case:
    • One 5.5 mm Tri-point screw.
    • One 13.5 mm Tri-point screw.
    • Lift the battery out of the upper case.
  19. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 19, afbeelding 1 van 2 MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement: stap 19, afbeelding 2 van 2
    • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
    • Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
    • Be careful not to rip out the fragile connector plug of the microphone assembly.
  20. MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement, DC-In Board: stap 20, afbeelding 1 van 1
    • Disconnect the DC-In board by pulling its connector away from the socket on the logic board.
Conclusie
89 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Reassembling: Make sure, the cable of the DC-In board is on the logic board-side of the screw hole when putting in the logic board. Otherwise the display data cable bracket won't fit in and you have to remove the board again.
So I hope, the DC-In board was really the cause of my problems. I changed the battery and the charging cable before and still had problems. At this moment my macbook loads again, but I don't know if its because of the board or again just luck. Thank you very much for the guide.
lichthexe - Antwoord
Thank you Team for wonderful blog, I had replaced DC-in board successfully.
~Dushyanta
Dushyanta - Antwoord
I just replaced the DC-in board but my Mac did not turn on. Any other suggestion?
gypsyp - Antwoord
Many thanks for this great manual. You helped me to prolong my old MacBook’s life and I saved a lot of money. Carry on the good work!
Yannick Baumann - Antwoord
Any possibilities to also show “how to upgrade the mother board”?
mats_kallmyr - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 54
Altijd: 59,555
