Ga door naar hoofdinhoud
MacBook Pro 13" Retina Display Mid 2014 Fan Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 3, afbeelding 1 van 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 3, afbeelding 2 van 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Battery Connector: stap 4, afbeelding 1 van 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 5, afbeelding 1 van 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 5, afbeelding 2 van 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 6, afbeelding 1 van 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: stap 7, afbeelding 1 van 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: stap 7, afbeelding 2 van 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: stap 7, afbeelding 3 van 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 8, afbeelding 1 van 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 8, afbeelding 2 van 2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 9, afbeelding 1 van 1
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 10, afbeelding 1 van 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 10, afbeelding 2 van 2
  11. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Fan: stap 11, afbeelding 1 van 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Fan: stap 11, afbeelding 2 van 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 12, afbeelding 1 van 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 12, afbeelding 2 van 2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 13, afbeelding 1 van 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 13, afbeelding 2 van 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 13, afbeelding 3 van 3
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 14, afbeelding 1 van 1
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 15, afbeelding 1 van 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 15, afbeelding 2 van 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: stap 15, afbeelding 3 van 3
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
Conclusie
28 andere personen hebben deze handleiding voltooid.
Sam Goldheart
466.454 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.524 handleidingen geschreven
4 opmerkingen
Very clear guide, and highly informative photos. It might be useful to add that the PL5 screws on the back of the case do not insert vertically. These insert at a slight angle and attempting to insert them straight will cause cross treading.
Robert Chave - Antwoord
Simple and clear step by step instructions.
cosilverturq - Antwoord
What is the use of the four foam stickers in step 9? Mine don’t stick anymore after taking out.
Visalbotr Chan - Antwoord
A mi me ha pasado lo mismo. Supongo que sirve para ejercer una pequeña presión sobre los tornillos. Yo le he puesto unas pegatinas, recortadas, de las que se usan para tope de muebles, para que no rocen, y creo que hacen el apaño.
Jose Luis -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 117
Altijd: 43,971
