Inleiding
Use this guide to replace the AirPort card.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
19 andere personen hebben deze handleiding voltooid.
2 opmerkingen
What happened when it says "no wifi hardware detect " after replacing airport card?
If you aware how to replace wi-fi antenna ?
