Ga door naar hoofdinhoud
MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: stap 3, afbeelding 1 van 3 MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: stap 3, afbeelding 2 van 3 MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: stap 3, afbeelding 3 van 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sam Goldheart
466.950 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
17.686 handleidingen geschreven
Één opmerking
tell me the size of screw driver
nigamyadav56 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 10,792
